Home » Archived » BIRT » Display mutiple rows in multiple page
Display mutiple rows in multiple page [message #84713] |
Thu, 27 October 2005 06:41  |
Originally posted by: bristow.startrekitalia.com
Hi all,
I have this problem: I obtain my data from jdbc source.
When the rows are greater than one, I'd like generate a report with
multiple page, one for every row obtained, and put one row for page.
Is possible this?
Pietro
Re: Display mutiple rows in multiple page [message #85296 is a reply to message #85062] |
Fri, 28 October 2005 10:54   |
Jason,
thanks for your answer.
I tried your suggest but it doesn't work or (more probably) I don't
understand how page break works.
I explain better what I need: I must generate a pdf that repeat the same
page and, for every page, use a different row of dataset.
I use 1.0.1. Can accomplish with this version or I have need of 2.0 version?
Pietro
Jason Weathersby ha scritto:
> Pietro
> In 1.0.1 this is possible only with PDF, using Page Break before or after in
> the properties tab.
> 2.0 will have more paging options.
> Jason Weathersby
> BIRT PMC
> "Pietro" <bristow@startrekitalia.com> wrote in message
> news:djqat2$cbr$1@news.eclipse.org...
>>Hi all,
>>Is possible this?
>>Thanks,
>>Pietro
Re: Display mutiple rows in multiple page [message #85339 is a reply to message #85296] |
Fri, 28 October 2005 12:32   |
Pietro,
You should be able to do this in 1.0.1, by
putting a table in design and then your data controls.
Then select all our detail controls and on the property editor, set Page
Break after to "Always".
Jason Weathersby
BIRT PMC
"Pietro Santurelli" <santurelli@inwind.it> wrote in message
news:djte38$bll$1@news.eclipse.org...
> Jason,
> version?
> Pietro
>> Pietro
>> in the properties tab.
>> Jason Weathersby
>> BIRT PMC
>>>Hi all,
>>>Is possible this?
>>>Thanks,
>>>Pietro
Re: Display mutiple rows in multiple page [message #85488 is a reply to message #85339] |
Fri, 28 October 2005 18:04   |
Jason,
I don't understand very well your answer. When I tried to apply it, the
program is blocked in an infinite loop.
What are detail controls? Can you send me an example?
Pietro
> Pietro,
> Jason Weathersby
> BIRT PMC
>>Jason,
>>version?
>>Thanks,
>>Pietro
>>>Pietro
>>>Jason Weathersby
>>>BIRT PMC
>>>>Hi all,
>>>>Is possible this?
>>>>Thanks,
>>>>Pietro
Re: Display mutiple rows in multiple page [message #85782 is a reply to message #85488] |
Mon, 31 October 2005 12:13  |
Pietro,
Here is a simple example that displays office information.
In PDF it does one office per page.
Jason Weathersby
BIRT PMC
news:dju79i$cpo$1@news.eclipse.org...
> Jason,
> Pietro
>> Pietro,
>> Jason Weathersby
>> BIRT PMC
>>>Jason,
>>>version?
>>>Thanks,
>>>Pietro
>>>>Pietro
>>>>after
>>>>Jason Weathersby
>>>>BIRT PMC
>>>>>Hi all,
>>>>>Is possible this?
>>>>>Thanks,
>>>>>Pietro
Current Time: Mon Jul 14 05:32:02 EDT 2025
Powered by FUDForum. Page generated in 0.24873 seconds
