Home » Newcomers » Newcomers » Passing command line parameters in debug mode
Passing command line parameters in debug mode [message #84703] Fri, 08 July 2005 12:00 Go to next message
Originally posted by: uuppal.salesforce.com
Hi, I am new to Eclispe, I have a porject in Eclispse that i need to run
in debug mode. I need to pass command line parameters. i did not see
any option to do that .
Thanks for your help.
Re: Passing command line parameters in debug mode [message #84718 is a reply to message #84703] Fri, 08 July 2005 12:25 Go to previous message
Steps:
Right click on your class containing the "main" method
Run As>Run...
Select Java Application
Click New
Go to the Arguments tab
Enter your program arguments
Hit Run
HTH
Darins
"Usman" <uuppal@salesforce.com> wrote in message
news:d9854e57d1661d55b7fb93c343947e44$1@www.eclipse.org...
Previous Topic:import
Next Topic:need help for correct CVS setting
Current Time: Mon Sep 29 15:14:21 EDT 2025
Powered by FUDForum. Page generated in 0.07926 seconds
