Re: [xcore] Codegen in Xcore [message #753459 is a reply to message #753448] |
Thu, 27 October 2011 10:59 |
Ed Merks Messages: 33142 Registered: July 2009 |
Hauke,
Comments below.
On 27/10/2011 11:52 AM, Hauke Fuhrmann wrote:
> Hi there,
> I just stumbled over the Xcore project that defines EMF models with an
> Xtext syntax. Do you have some more information about the intended
> architecture available?
No, just the code itself right now.
> From Ed's example in his blog I understand you can for example define
> Operation implementations in Xcore.
Yes.
> So far I thought you cannot do this in ecore,
No, you can't in Ecore.
> so you have to implement an operation in the generated Java code.
No, the operation implementation is generated from the Xbase logic in
the Xcore model; it can also be interpreted dynamically.
> How is this Operation implementation handled?
I just finished committing all the changes to the EMF core to support
the Xcore base that's at github, so with the next 2.8 build of EMF
(tomorrow I think), you'll be able to try it out more easily.
> Is it mapped to something in the genmodel such that it will be
> available in the generated Java classes?
We have a preprocessing phase at compiles it down to Java and encodes it
as an EAnnotation; the generator emits that Java code directly.
> Is the Xcore to genmodel transformation just a M2M transformation
Yes.
> or does it also generate Java code for such feature that ecore
> currently did not have.
During generation, we preprocess the Ecore model (which knows its
mapping back to Xcore) to generate Java code from the Xcore operation
bodies (XBlockExpressions).
> Does this question make sense or do I bark up the wrong tree?
Sven and I will be doing a demo at EclipseCon Europe next week. Maybe
you'll be there?
> Cheers,
> Hauke
Ed Merks
Re: [xcore] Codegen in Xcore [message #754241 is a reply to message #754233] |
Tue, 01 November 2011 15:18 |
Hauke,
I was told that all the sessions will be recorded so you'll be able to
watch the recorded session at some point.
Ed
On 01/11/2011 3:46 PM, Hauke Fuhrmann wrote:
> Am 27.10.2011 12:59, schrieb Ed Merks:
>> you'll be there?
> Ed, unfortunately I cannot be there.
> Cheers,
> Hauke
Ed Merks
FUDForum. Page generated in 0.03531 seconds
