Home » Modeling » GMF (Graphical Modeling Framework) » Useful Tabbed Pane in GMF
Useful Tabbed Pane in GMF [message #84573] Mon, 11 December 2006 11:19 Go to next message
Originally posted by: renwart.lippmann.lu
Hi everybody,
I'm testing GMF now but I'm afraid to see that all my model have to be on a
single diagram.
I see that a "tabbed pane" is not yet implemented (or another similar way to
split my diagram into smaller modules). When you have a large
metamodel/model with a lots of nodes/connections, You can easily imagine
that it's really annoying...
Perhaps this helpful "tabbed pane" is already existing ? If yes, I haven't
seen it!
If no, I hope this will be included in GMF 2.0...
But perhaps somebody has integrated his own tabbed pane classes in GMF 1.0
Thanks for help!
benren.
Re: Useful Tabbed Pane in GMF [message #84576 is a reply to message #84573] Mon, 11 December 2006 11:45 Go to previous messageGo to next message
Hello Ben,
You can generate several different diagrams for different "aspects" of your
metamodel and use these diagrams simultaneously - see UML2 diagrams. Do you
really need several tabs on the same diagrams or several editors is enough
for you?
Alex Shatalin
Re: Useful Tabbed Pane in GMF [message #84584 is a reply to message #84576] Tue, 12 December 2006 02:56 Go to previous messageGo to next message
Alex Shatalin a écrit :
> Hello Ben,
> your metamodel and use these diagrams simultaneously - see UML2
> diagrams. Do you really need several tabs on the same diagrams or
> several editors is enough for you?
> Alex Shatalin
Hi Alex,
I'd like to "link" elements from one diagram to another ones... Tabs are
helpful because we stay in the same diagram so we can access all the
existing metamodel elements. If I use several diagrams is it possible to
do that ?
Re: Useful Tabbed Pane in GMF [message #84593 is a reply to message #84584] Tue, 12 December 2006 07:04 Go to previous message
Hello Ben,
You can add a shortcut to the element form diagram-1 into the diagram-2 as
a result, corresponding element will be visible on second diagram.
To update diagram-1 after modification of diagram-2 without pressing save
you can use same (shared) editing domain for both diagram editors.
Alex Shatalin
Previous Topic:can't add two label mapping two a node mapping
Next Topic:Child Reference is only adhered at creation time
Current Time: Fri Jul 18 10:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.04979 seconds
