Unable to locate any entries for lookup=dv.PNG; element=(name:device) in any plugin.xml file in all [message #84387] |
Wed, 26 October 2005 13:59  |
Originally posted by: bidyut.uppervision.com
I am trying to use Birt integration with my web application. I am doing an
integration at API level, not at servlet level. I have downloaded the
standalone version of the chart engine(1.0.1). I wrote a test program to
create the chart and when I run the program it gives me the following error:
SEVERE: Exception
org.eclipse.birt.chart.exception.ChartException: Unable to locate any
all of the available plugins
org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObjec t(PluginSettings.java:675)
org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginS ettings.java:338)
com.uppervision.consoleMgr.reports.ChartBuilder.exportChartT oPNG(ChartBuilder.java:188)
com.uppervision.consoleMgr.reports.ChartBuilderTest.main(Cha rtBuilderTest.java:13)
Is there any settings I am missing?
Bidyut
Re: Unable to locate any entries for lookup=dv.PNG; element=(name:device) in any plugin.xml file in [message #84519 is a reply to message #84485] |
Wed, 26 October 2005 18:41  |
Thanks. I tried doing that. Also I set the system property to "standalone".
Now I get the following error:
SEVERE: Exception
org.eclipse.birt.chart.exception.ChartException: $NO-RB$ null
org.eclipse.birt.chart.factory.Generator.build(Generator.jav a:290)
What is this cryptic error? Sorry, I am new to this charting.
Bidyut
"Ricardo" <ricardo7772@hotmail.com> wrote in message
news:djotjt$odd$1@news.eclipse.org...
> Bidyut Pattanayak wrote:
>> an integration at API level, not at servlet level. I have downloaded the
>> error:
>> SEVERE: Exception
>> in all of the available plugins
>> at
>> at
>> at
>> at
>> Thanks
>> Bidyut
> Hi!, sorry about my bad english.
> I believe that you should download birt-chart-1_0_1, and put the jars into
> the same directory of the other jars,and set your CLASSPATH to access to
> those jars.
> Good Luck.
FUDForum. Page generated in 0.04634 seconds
