Ant script on Linux different behavior file not found [message #83597] |
Fri, 15 September 2006 03:48  |
Originally posted by: Bjorn.Vanhauwaert.barco.com
I am stuck trying to get tptp running in an ant script on a debian machine,
i had it running on windows but some wierd behavior happend when i run the
script on the debian.
I think i might be a tptp property i am setting wrong, or the ant lib that
returns a different path in linux than on windows (
/com.barco.compose.metadata/MetaPacketTest.testsuite )
MetaPacketTest.testsuite is not in the /com.barco.compose.metadata but i
dont know how i am able to change the path there.
Thank you
this is the error:
Buildfile: bms-metadata-build-tptp.xml
test-execution:
adding file MetaPacketTest.testsuite
adding file src/com/barco/compose/metadata/test/MetaPacketTest.testsuite
Test started!
Test 'MetaPacketTest.testsuite' executing
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1$Diagno sticWrappedException:
org.eclipse.core.internal.resources.ResourceException: Resource
/com.barco.compose.metadata/MetaPacketTest.testsuite does not exist.
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:307)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.loadModelElement(AbstractTestExecutionService.java:65 3)
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.loadTestSuite(AbstractTestExecutionService.java:672)
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.beforeLaunch(AbstractTestExecutionService.java:235)
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.execute(AbstractTestExecutionService.java:422)
org.eclipse.hyades.automation.server.AbstractService.execute (AbstractService.java:43)
org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv iceProxy.java:140)
org.eclipse.hyades.automation.core.utils.ReusableThread.run( ReusableThread.java:131)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:311)
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:187)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:288)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:279)
org.eclipse.hyades.models.hierarchy.util.HierarchyURIConvert erImpl$WorkbenchHelper.createPlatformResourceInputStream(Hie rarchyURIConverterImpl.java:290)
org.eclipse.hyades.models.hierarchy.util.HierarchyURIConvert erImpl.createPlatformResourceInputStream(HierarchyURIConvert erImpl.java:368)
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:449)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:892)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
.... 9 more
this is the ant file:
<project name="BMS Meta Data compilation"
default="main"
xmlns:tptp="antlib:org.eclipse.hyades.automation.client.adapters.ant ">
<property name="tptp.automation.eclipse"
value="/users/software/user/apps/eclipse/32" />
<property name="tptp.test.workspace"
value=" /users/software/user/apps/cruisecontrol/25/projects/bms-meta data/ "/>
<property name="tptp.test.project" value="com.barco.compose.metadata"/>
<property name="project.dir"
value="${tptp.test.workspace}${tptp.test.project}"/>
<property name="filemask" value="**/MetaPacketTest.testsuite" />
<target name="main" depends="test-execution"/>
<!-- Execute TPTP test suites -->
<target name="test-execution" description="Executes TPTP Test Suites using
default TPTP Ant Tasks">
<!-- Execute a TPTP test suite using the test task and providing the
workspace -->
<tptp:execution resultsrefid="tptp.test.results">
<fileset dir="${project.dir}">
<include name="${filemask}"/>
</fileset>
</tptp:execution>
</target>
</project>
Re: Ant script on Linux different behavior file not found [message #83833 is a reply to message #83777] |
Wed, 20 September 2006 03:24   |
If i use the script below i get the same result. currently i am checking the
code and digging deeper in it, writig some output to the screen to try to
locate the error or my mistake.
currently the script executes the client with these properties maybe they
might be of some use:
Service:org.eclipse.hyades.test.tools.core.execute
{classpath=,
workspace=/users/software/tspiesse/apps/cruisecontrol/25/pro jects/bms-metadata,
quiet=false, overwrite=false, suite=[MetaPacketTest.testsuite],
resultsrefid=tptp.test.results, project=com.barco.compose.metadata}
properties:{classpath=,
script:
default="main"
value="/users/software/tspiesse/apps/eclipse/32" />
value=" /users/software/tspiesse/apps/cruisecontrol/25/projects/bms- metadata/ "/>
<!--<property name="tptp.test.project"
value=" /users/software/tspiesse/apps/cruisecontrol/25/projects/bms- metadata/com.barco.compose.metadata "/>-->
workspace -->
<filelist id="testfile" dir="${project.dir}"
files="MetaPacketTest.testsuite"/>
</tptp:execution>
</target>
<!-- Interrogate test suite results for verdict -->
</project>
"Joe Toomey" <jptoomey@us.ibm.com> wrote in message
news:eemcoc$pbt$2@utils.eclipse.org...
> Hi Bjorn,
> This sounds like a defect. Can you try your ant script using a filelist
> instead of a fileset and see if you get the same behavior?
> --Joe
FUDForum. Page generated in 0.04127 seconds
