using http proxy for downloading [message #7493] |
Wed, 19 March 2008 10:23  |
I'm working on custom packaging and it looks that it would be very
useful for me to use http proxy for downloading features/plugins.
Is it possible to configure EPP builder to use http proxy?
If yes - how to do such a thing?
Thanks in advance,
Tomek
Re: using http proxy for downloading [message #7507 is a reply to message #7493] |
Thu, 20 March 2008 02:55  |
Originally posted by: mknauer.innoopract.com
Tomasz Pik wrote:
> Hello,
> Thanks in advance,
> Tomek
Yes, that's easy. You have to set the following Java properties on the
command line or in your launch configuration: http.proxyHost,
http.proxyPort.
If you are starting EPP from within Eclipse, you have to add these
properties to the vm parameters with
-Dhttp.proxyhost=IP.adr.of.the.server -Dhttp.proxyport=8080, if you are
starting the EPP build from command line you can set it with
eclipse otherParams... -vm -Dhttp.proxyhost=myproxy -Dhttp.proxyport=8000
For more information about that topic have a look at
http://java.sun.com/javase/6/docs/technotes/guides/net/proxi es.html
Markus
Re: using http proxy for downloading [message #576300 is a reply to message #7493] |
Tomasz Pik wrote:
> Hello,
> Thanks in advance,
> Tomek
http.proxyPort.
Markus
FUDForum. Page generated in 0.06962 seconds
