Home » Archived » EPP » using http proxy for downloading
using http proxy for downloading [message #7493] Wed, 19 March 2008 10:23 Go to next message
I'm working on custom packaging and it looks that it would be very
useful for me to use http proxy for downloading features/plugins.
Is it possible to configure EPP builder to use http proxy?
If yes - how to do such a thing?
Thanks in advance,
Tomek
Re: using http proxy for downloading [message #7507 is a reply to message #7493] Thu, 20 March 2008 02:55 Go to previous message
Originally posted by: mknauer.innoopract.com
Tomasz Pik wrote:
> Hello,
> Thanks in advance,
> Tomek
Yes, that's easy. You have to set the following Java properties on the
command line or in your launch configuration: http.proxyHost,
http.proxyPort.
If you are starting EPP from within Eclipse, you have to add these
properties to the vm parameters with
-Dhttp.proxyhost=IP.adr.of.the.server -Dhttp.proxyport=8080, if you are
starting the EPP build from command line you can set it with
eclipse otherParams... -vm -Dhttp.proxyhost=myproxy -Dhttp.proxyport=8000
For more information about that topic have a look at
http://java.sun.com/javase/6/docs/technotes/guides/net/proxi es.html
Markus
Re: using http proxy for downloading [message #576300 is a reply to message #7493] Thu, 20 March 2008 02:55 Go to previous message
Tomasz Pik wrote:
> Hello,
> Thanks in advance,
> Tomek
http.proxyPort.
Markus
Previous Topic:using http proxy for downloading
Next Topic:Ganymede M6
Current Time: Tue Jul 15 15:49:38 EDT 2025
Powered by FUDForum. Page generated in 0.05747 seconds
