Removing action sets from a perspective [message #83359] |
Thu, 26 June 2003 15:48  |
I'm writing a new perspective, and there are some action sets that I don't
really want visible the first time that the perspective is loaded, without
having to use the "Customize Perspective" dialog. These include the
"External Tools", "Navigator", and a couple of others. I can't seem to find
a way to get rid of them in the perspective factory, and I've tried the
IWorkbenchPage.hideActionSet(), but it doesn't work. So, is there any way
that it can be done? Thanks.
Del.
Re: Removing action sets from a perspective [message #84191 is a reply to message #83359] |
Fri, 27 June 2003 14:30  |
Originally posted by: lynne_kues.oti.com
I opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=39435 for the fact
that hideActionSet is not working. I think it should in your scenario.
Could you also check out https://bugs.eclipse.org/bugs/show_bug.cgi?id=36968
which talks about improving action set contributions functionality for 3.0.
The bug report specifically mentions associating particular action sets with
each perspective. I assume what is discussed will solve your problem - if
not, please update the bug report with information about what you are doing.
As to how to get around this for now, there is no way that I can tell using
public API. You could try using internal API (e.g.,
setActionSets(IActionSetDescriptor[]), but that's not the "right" thing to
do.
"Del" <delmyers@cs.uvic.ca> wrote in message
news:bdfi55$2v7$1@rogue.oti.com...
find
> Del.
FUDForum. Page generated in 0.03570 seconds
