Home » Eclipse Projects » Linux Tools Project » Error installing linuxtools through update manager
Error installing linuxtools through update manager [message #7465] Wed, 13 May 2009 12:33 Go to next message
I've been trying to install Linux tools through Eclipse update manager,
but am unfortunately getting an error. Following is the error I'm getting:
Network connection problems encountered during search.
Unable to access
"http://download.eclipse.org/technology/linuxtools/update".
Unable to access site:
"http://download.eclipse.org/technology/linuxtools/update" [Server
returned HTTP response code: "404 Not Found" for URL:
http://download.eclipse.org/technology/linuxtools/update.]
Server returned HTTP response code: "404 Not Found" for URL:
I'm running Eclipse 3.4.1 on Ubuntu 8.04.
I'll really appreciate any help.
Re: Error installing linuxtools through update manager [message #7478 is a reply to message #7465] Wed, 13 May 2009 17:34 Go to previous messageGo to next message
> Unable to access
Are you perhaps behind a proxy or something? This works for me. You
can verify by appending a content.jar to the above and seeing if you can
access it in a browser.
Andrew
Re: Error installing linuxtools through update manager [message #7489 is a reply to message #7478] Wed, 13 May 2009 17:46 Go to previous messageGo to next message
Andrew,
Thanks for your response. I'm probably behind a proxy server. However,
when I append content.jar to the address and try to access that through a
web browser, it allows me to download the jar file. So I don't know why it
wouldn't work with Eclipse update manager.
I'll appreciate any suggestions you may have.
Thanks!
Re: Error installing linuxtools through update manager [message #7500 is a reply to message #7489] Thu, 14 May 2009 09:12 Go to previous messageGo to next message
My only suggestion is to look at the Eclipse proxy settings as p2 (the
update manager) uses them.
If you can't get the update manager working, just download the zip [1]
and use _it_ as input to the update manager. See:
http://wiki.eclipse.org/Linux_Tools_Project/User_Guide#Insta llation
Good luck,
Andrew
[1]
http://www.eclipse.org/downloads/download.php?file=/technolo gy/linuxtools/S200905081609/linuxtools-Update-incubation-0.2 .0.zip
Re: Error installing linuxtools through update manager [message #7510 is a reply to message #7500] Thu, 14 May 2009 18:00 Go to previous messageGo to next message
I was finally able to use the update manager to install the linux tools.
In order to make that work, I had to run eclipse as the super-user.
Unfortunately, when I use the OProfile, I don't get any output. Instead, I
get an error:
FATAL: An error occurred with opxml.
Reason: The opxml binary cannot be read or executed. Either your user does
not have sufficient permissions, or the install script was not run.
I'm not able to find the opxml binary, although I did install OProfile
using install-noconsolehelper.sh.
Re: Error installing linuxtools through update manager [message #7522 is a reply to message #7510] Fri, 15 May 2009 08:37 Go to previous message
That doesn't make any sense if you extracted eclipse from an eclipse.org
download into some directory in your home directory.
> get an error:
consolehelper isn't a Debian thing AFAIK. Kent will be able to provide
more guidance here.
Andrew
Re: Error installing linuxtools through update manager [message #566044 is a reply to message #7465] Wed, 13 May 2009 17:34 Go to previous message
> Unable to access
Andrew
Re: Error installing linuxtools through update manager [message #566062 is a reply to message #7478] Wed, 13 May 2009 17:46 Go to previous message
Andrew,
Thanks!
Re: Error installing linuxtools through update manager [message #566080 is a reply to message #7489] Thu, 14 May 2009 09:12 Go to previous message
Good luck,
Andrew
[1]
Re: Error installing linuxtools through update manager [message #566106 is a reply to message #7500] Thu, 14 May 2009 18:00 Go to previous message
get an error:
Re: Error installing linuxtools through update manager [message #566125 is a reply to message #7510] Fri, 15 May 2009 08:37 Go to previous message
> get an error:
more guidance here.
Andrew
Previous Topic:Error installing linuxtools through update manager
Next Topic:Valgrid issues on Ubuntu
Current Time: Wed Jul 16 19:12:45 EDT 2025
Powered by FUDForum. Page generated in 0.06778 seconds
