Home » Language IDEs » Java Development Tools (JDT) » Programmatically JAR creation
Programmatically JAR creation [message #7436] Mon, 28 April 2003 11:47 Go to next message
Originally posted by: nospam_danilo.floripa.com.br
Hi.
In a project I have a Ejb jar file structore inside the bin
workspace directory. Like this :
/bin
com
sigea
ExecutaMatriculaHome.class
ExecutaMatricula.class
ExecutaMatriculaBean.class
META-INF
ejb-jar.xml
jboss.xml
I want to put this inside a JAR file to be deployed on the server.
I am able to use the JarPackageData successfully.
My question is how to get the elements to the array passed to the
setElements(filestoExport) function.
What is the right way of do it ?
Danilo.
Re: Programmatically JAR creation [message #8275 is a reply to message #7436] Tue, 29 April 2003 05:04 Go to previous message
Originally posted by: daniel.megert.gmx.net
Danilo Luiz Rheinheimer wrote:
> Hi.
> /bin
> com
> sigea
> META-INF
> ejb-jar.xml
> jboss.xml
The JarPackageData expects the resources and/or Java elements that you
use as source. It then figures out which class files to package (e.g. if
you have type A and B in A.java it will package A.class and B.class). If
you want to create a JAR/ZIP out of the output folder then you better
use java.util.jar classes to do so.
Dani
Previous Topic:Eclipse 2.2 vs. Eclipse 3.0
Next Topic:IWorkinCopy should extend ICompilationUnit, and not the opposite
Current Time: Fri Jun 06 11:17:28 EDT 2025
Powered by FUDForum. Page generated in 0.26817 seconds
