Home » Archived » M2M (model-to-model transformation) » union of meta models
union of meta models [message #82676] Thu, 29 May 2008 10:20 Go to next message
Originally posted by: monnet2.etu.unige.ch
I am a university student and doing some studies about meta model
composition.
I am new with ATL and I read the basic examples and the manual.
Now I started with my own simple example. My objective is to take 2 meta
models and do an union to produce a composed meta model.
So I took the Family.ecore and Persons.ecore meta models, and I want to
get a FamilyUnionPersons.ecore. The resulting meta model should contain
then elements of both meta models:
- Family
- Member
- Persons
For the moment, as I am beginning with ATL and I am faced to some
dificulties, I would like to at least produce a resulting meta model which
will contain elements of the Family.ecore meta model. I tried with Ecore
eClasses and now I am trying with Ecore EPackage in order to try to have
the EPackages from the Families meta model in the resulting meta model.
Here is the ATL file i created in order to get this resulting Ecore meta
model:
module simpleUnion; -- Module Template
create FamiliesUnionPersons : Ecore from Families : Ecore, Persons : Ecore;
rule CopyOfFamilies {
from
fc : Families!"ecore:EPackage"
to
rc : FamiliesUnionPersons!"ecore:EPackage" (
name<-fc.name
I created the launch configuration with:
Meta model: Ecore;
Source Models: Families.ecore, Persons.ecore;
Target Model: FamiliesUnionPersons.ecore
I am getting this error message in the console:
SEVERE: ****** BEGIN Stack Trace
SEVERE: message: cannot find metamodel element ecore:EPackage in model
Families
SEVERE: A.main() : ??#22 null
SEVERE: local variables = {self=simpleUnion : ASMModule}
SEVERE: local stack = []
SEVERE: A.__matcher__() : ??#1 null
SEVERE: A.__matchCopyOfFamilies() : ??#2 null
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
SEVERE: cannot find metamodel element ecore:EPackage in model Families
java.lang.RuntimeException: cannot find metamodel element ecore:EPackage
in model Families
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:91)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:296)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:759)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
Do you have any idea on what I am doing wrong?
Thank you in advance for any help.
Re: union of meta models [message #82685 is a reply to message #82676] Thu, 29 May 2008 14:54 Go to previous message
--------------060301080007030902060305
Hi Xavier,
Your rule should be updated as the following:
from
fc : Ecore!EPackage
to
rc : Ecore!EPackage (
name<-fc.name
Freddy.
Xavier Monnet a
Previous Topic:[ATL] how to set attribute with non-stadard primitive value?
Next Topic:ATL: output xsd
Current Time: Wed Jul 16 21:45:44 EDT 2025
Powered by FUDForum. Page generated in 1.26070 seconds
