Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #82303 is a reply to message #82289] |
Mon, 07 May 2007 17:18   |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Julia,
Can you send me the xsd's/ecores involved? Then I can try myself to see where/how it fails.
gr. Martin
Julia wrote:
> Hi Martin,
> Yes I did do that and highlighted both ecore files to create the
> meatadata package.jdo file. Still got the NPE.
> In an attempt to further see if there was some other problem with the
> xsd files, I combined the 2 separate xsd files into one -
> portletentities.xsd. This eliminated the import statement.
> It still give me the null ptr exception.
> It appears to fail on one element that reference other elements within
> the xsd but 4 level deep eg <elementA> -> <elementB, max unbounded> ->
> <elementC, max unbounded> -> <elementD,max unbounded> -> String.
> There doesn't appear to have any problems 3 level deep (ie no elementB
> or elementA).
> Is there something else I need to do?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #605339 is a reply to message #82289] |
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> or elementA).
The Netherlands
FUDForum. Page generated in 0.02752 seconds
