Home » Eclipse Projects » Remote Application Platform (RAP) » accessing the HttpServlet or ServletContext
accessing the HttpServlet or ServletContext [message #81852] Mon, 07 April 2008 09:08 Go to next message
Originally posted by: pfischer06.fast-mail.org
Hello all,
I need to access the HttpServlet or ServletContext of the running
BridgeServlet before the first request. That's why I can't use
org.eclipse.rwt.RWT.
Is there an easy way to get one of them in my own bundle?
regards
Peter
Re: accessing the HttpServlet or ServletContext [message #82047 is a reply to message #81852] Wed, 09 April 2008 07:57 Go to previous messageGo to next message
Hi Peter,
can you explain what you want to do? I'm not sure whether I understand
your question but you can use
RWT.getRequest().getSession().getServletContext() to get the servlet
context. However this only works if you are within a request.
Stefan.
Peter Fischer schrieb:
> Hello all,
> regards
> Peter
Re: accessing the HttpServlet or ServletContext [message #82149 is a reply to message #82047] Wed, 09 April 2008 13:34 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
Hi Peter,
unfortunately I don't have an answer to your question right away. But as
the problem you're describing is nothing special to RAP, but belongs to
every servlet mapped to osgi's http-service, you may have a look at the
equinox mailinglist/newsgroup whether this question has already been
raised there.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Stefan Röck [mailto:stefan.roeck@cas.de]
Bereitgestellt: Mittwoch, 9. April 2008 13:58
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: accessing the HttpServlet or ServletContext
Betreff: Re: accessing the HttpServlet or ServletContext
Hi Peter,
Stefan.
> Hello all,
> regards
> Peter
Re: accessing the HttpServlet or ServletContext [message #82992 is a reply to message #82047] Tue, 15 April 2008 07:30 Go to previous messageGo to next message
Hello Stefan,
we use rap as frontend of a non osgied system. Beside rap with the
servletbridge, we start a spring context inside the same webapp. Now we
would like to provide this spring-context, which is contained in the
ServletContext, to our rap-ui-bundles inside the osgi-runtime. This has to
be done bevore the first request, maybe in a bundle activator.
regards,
Peter
Re: accessing the HttpServlet or ServletContext [message #83021 is a reply to message #82992] Tue, 15 April 2008 08:40 Go to previous messageGo to next message
the bundle Activator seems to be a reasonable choice. If your spring
context is loaded using the webapp classloader you can configure the
web.xml to make the necessary classes available within the RAP app. See
'extendedFrameworkExports' in the org.eclipse.rap.demo.feature's web.xml
for more information. Note that you must use package import instead of
bundle-dependencies to provide the according types at development time.
Ciao
Frank
Von: Peter Fischer [mailto:pfischer06@fast-mail.org]
Bereitgestellt: Dienstag, 15. April 2008 13:30
Hello Stefan,
to be done bevore the first request, maybe in a bundle activator.
regards,
Peter
Re: accessing the HttpServlet or ServletContext [message #83118 is a reply to message #83021] Tue, 15 April 2008 13:31 Go to previous messageGo to next message
Hello Frank,
This way we can use the classes deployed outside the osgi. That's it how
we use it now with the sping context as static member of one imported
class.
This works fine, but how about non static access to the spring-context. I
thougt it would be a better way to get the instance contained in the
ServletContext direct?
regards,
Peter
Re: accessing the HttpServlet or ServletContext [message #83202 is a reply to message #83118] Wed, 16 April 2008 00:08 Go to previous message
Hi Peter,
I'm not sure if I really understand, but you can access the OSGi
provided HttpContext using:
ServiceReference reference ...
String name = HttpContextExtensionService.class.getName();
ServiceReference serviceRef = context.getServiceReference( name );
HttpContextExtensionService service
= ( HttpContextExtensionService )context.getService( serviceRef );
HttpContext rapContext
= service.getHttpContext( reference, "org.eclipse.rap.httpcontext" );
Unfortunately I don't know a way to get to the ServletContext object
this maps to. As this belongs to the equinox stuff, maybe there is more
information available in the equinox newsgroup/mailinglist.
Ciao
Frank
Bereitgestellt: Dienstag, 15. April 2008 19:31
Hello Frank,
> See 'extendedFrameworkExports' in the org.eclipse.rap.demo.feature's
> web.xml for more information. Note that you must use package import
> instead of bundle-dependencies to provide the according types at
development time.
class.
I thougt it would be a better way to get the instance contained in the
regards,
Peter
Previous Topic:call for help . setShowStatusLine seems not working outside the preWindowOpen
Next Topic:[ANN] RAP 1.1 M3 released
Current Time: Mon Jul 21 23:57:09 EDT 2025
Powered by FUDForum. Page generated in 0.10122 seconds
