Home » Eclipse Projects » Remote Application Platform (RAP) » TreeViewer sorts elements by name
TreeViewer sorts elements by name [message #7292] Wed, 14 March 2007 13:38 Go to next message
I use a TreeViewer to navigate through my Data. Everything is fine,
without the order. So i add a special ViewSorter.
Code Snip
private ViewerSorter getRevisionSorter() {
return new ViewerSorter(){
protected Comparator getComparator() {
return new Comparator() {
public int compare(Object arg0, Object arg1) {
System.out.println(arg0.getClass() + " -> " + arg0);
if(arg0 instanceof Revision && arg1 instanceof Revision) {
return (int) (((Revision) arg0).getRevisionNumber() - ((Revision)
arg1)
.getRevisionNumber());
else
return arg0.toString().compareTo(arg1.toString());
<<< Snap
The System out shows me that the Objects passed to the Comparator are
Strings. After looking at my ContentProvider I am sure that I have not
Strings in the Tree.
Is this a limitation in Milestone2?
Karsten
Re: TreeViewer sorts elements by name [message #7998 is a reply to message #7292] Wed, 14 March 2007 16:08 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
The ViewerSorter works as expected from our experience, here is a code
snippet from our online demo and the output:
viewer.setSorter( new ViewerSorter() {
public int compare( final Viewer viewer,
final Object e1,
final Object e2 )
System.out.println( e1.getClass() + " -> " + e1 );
String name1 = Util.getName( ( ( IUser )e1 ) );
String name2 = Util.getName( ( ( IUser )e2 ) );
return name1.compareTo( name2 );
class org.eclipse.rap.showcase.model.User ->
org.eclipse.rap.showcase.model.User@57807a
It seems to be a problem on your end.
Jochen
Karsten Panier wrote:
> Code Snip
> arg0);
> Revision) {
> arg0).getRevisionNumber() - ((Revision) arg1)
> else
> return
> <<< Snap
> Regards
> Karsten
Re: TreeViewer sorts elements by name [message #8274 is a reply to message #7998] Thu, 15 March 2007 06:13 Go to previous message
I found my mistake. I override the method getComparer of ViewerSorter.
Now I override the method compare(Viewer,Object,Object) of the
ViewerComparator.
Thanks.
Karsten
Jochen Krause schrieb:
> final Object e1,
> final Object e2 )
> Cheers,
> Jochen
>> Code Snip
>> arg0);
>> Revision) {
>> else
>> return
>> <<< Snap
>> Regards
>> Karsten
Previous Topic:Restore minimized application or shell
Next Topic:Browser Buttons and Menue
Current Time: Sun Jul 13 10:47:04 EDT 2025
Powered by FUDForum. Page generated in 0.02914 seconds
