Home » Archived » Test and Performance Tools Platform (TPTP) » Execution Time Analysis Fails Due To OutOfMemoryException
Execution Time Analysis Fails Due To OutOfMemoryException [message #81756] Fri, 25 August 2006 11:39 Go to next message
Originally posted by: wolfgang.rohregger.mci.edu
Hi!
I'm trying to profile an Eclipse RCP application. The app is using
hibernate to connect to a database. At some point (the one I want to
profile) it starts fetching huge amounts of data from the db. During
non-profiling execution a heap space of up to 1.5 GB is required at this
point. After this it should only require between 700 - 1500 MB.
Now then trying to make an Execution Time Analysis on the app
(specifically only including the top level package of one plugin) the
profiling aborts at the point where it should start loading tons of data
from the db:
2006-08-25 17:23:55,640 ERROR [main] (FunErrorDialog.java:168) -
Migrationsfehler-Migration fehlgeschlagen:null
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:350)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:479)
at edu.mci.fun.migration.MigrationView.migrate(MigrationView.ja va:314)
at edu.mci.fun.migration.MigrationView.access$1(MigrationView.j ava:278)
edu.mci.fun.migration.MigrationView$2.widgetSelected(Migrati onView.java:269)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at edu.mci.fun.gui.FunStartup.run(FunStartup.java:97)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.OutOfMemoryError: Java heap space
The documentation states somewhere that when profiling apps with much
data, one should profile to a file. I set this in the Profiling
Execution Dialog, in the tab called "Destination".
This didn't help either.
How would I profile the application even though it's producing a huge
amount of objects/data/method calls?
Wolfgang Rohregger
Re: Execution Time Analysis Fails Due To OutOfMemoryException [message #81896 is a reply to message #81756] Tue, 29 August 2006 05:51 Go to previous message
Wolfgang Rohregger schrieb:
> Hi!
> from the db:
VM Parameters seem to be ignored by profile launch configuration:
"-Xms1024m -Xmx1600m".
The VM of the application only gets 64M instead of 1600M.
Could this be a bug?
Wolfgang Rohregger
Previous Topic:Can TPTP provides Java Call Graph?
Next Topic:firefox and tptp
Current Time: Fri Jul 25 00:43:56 EDT 2025
Powered by FUDForum. Page generated in 0.04611 seconds
