Problems occurred when invoking code from plug-in: "org.eclipse.jface" [message #81701] |
Wed, 09 March 2005 12:54  |
Originally posted by: teascape.hotmail.com
I am testing eclipse 3.1M5a with wtp 1.0M3. Everything seems fine
yesterday.
But, suddenly today I am getting the following message when I try to
create a
J2EE Web Project:
!ENTRY org.eclipse.jface 4 2 2005-03-09 09:06:58.802
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.jst.server.generic.internal.core.ServerTypeDefin itionUtil.getServerTypeDefinition(ServerTypeDefinitionUtil.j ava:61)
org.eclipse.jst.server.generic.internal.core.GenericServerRu ntimeTargetHandler.getClasspathContainerLabel(GenericServerR untimeTargetHandler.java:62)
org.eclipse.jst.server.core.internal.RuntimeClasspathContain er.getDescription(RuntimeClasspathContainer.java:56)
org.eclipse.jdt.internal.ui.packageview.ClassPathContainer.g etLabel(ClassPathContainer.java:163)
org.eclipse.jdt.ui.JavaElementLabels.getTextLabel(JavaElemen tLabels.java:333)
org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getText(JavaUILabelProvider.java:161)
org.eclipse.jst.common.navigator.internal.java.PackageExplor erLabelProvider.getText(PackageExplorerLabelProvider.java:56 )
org.eclipse.wst.common.navigator.views.NavigatorContentServi ceLabelProvider.getText(NavigatorContentServiceLabelProvider .java:114)
org.eclipse.jface.viewers.DecoratingLabelProvider.getText(De coratingLabelProvider.java:118)
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:208)
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:1712)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:206)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:86)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1015)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:490)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:352)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1655)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:404)
org.eclipse.wst.common.navigator.views.CommonViewer.createTr eeItem(CommonViewer.java:193)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:383)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:363)
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:799)
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:810)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:179)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:866)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:851)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:3525)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:3553)
at org.eclipse.swt.widgets.Composite.WM_NOTIFY(Composite.java:9 94)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3075 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3480 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:154 3)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:218)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:2710)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3057 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:2305)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 19)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2539)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
What is going on? Can anyone help?
teascape
FUDForum. Page generated in 0.07632 seconds
