How to open a View as modal? [message #81683] |
Wed, 29 June 2005 05:15  |
Originally posted by: sangmin.lee.ge.com
I'm beginner for Eclipse.
1. I made a View. (i don't care if this is View or not)
2. I want to open this like Dialog. (if this is open state, user have to
be not able to select anywhere except this view.)
3. In the View, when user select a button, the View return String Value.
How can i do for this?
if anyone knows the way, please let me know that.
thank you
Re: How to open a View as modal? [message #82092 is a reply to message #81683] |
Wed, 29 June 2005 17:03  |
Originally posted by: user.server.net
Your problem description is rather vague...
I am assuming, you are developing a Java based application and "view"
means Frame/Window, then you could try the setModal method of your view.
But check also the API documentation for the version of the Virtual
Machine your are using.
Hope this helps.
> thank you
FUDForum. Page generated in 0.08248 seconds
