Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Howto use xsd2Ecore so that the xmi-files can be validated with xsd?
Howto use xsd2Ecore so that the xmi-files can be validated with xsd? [message #743162] |
Fri, 21 October 2011 07:25 |
Daniel Engelhardt Messages: 11 Registered: November 2010 |
I have got a problem with my Ecore meta models. I created two Ecore meta models from two xsd files describing different namespaces in XML (let's say AAA and BBB). These xsd files reference each other (or: on references elements of the other) and so do these two ecore files.
Now, I want to create an xmi file (using "Create dynamic instance" for example) which is supposed to look like this:
<?xml version="1.0" encoding="ASCII"?>
<aaa:DocumentRoot xmi:version="2.0" xmlns:xmi="http:SLASHSLASHwww.omg.org/XMI" xmlns:xsi="http:SLASHSLASHwww.w3.org/2001/XMLSchema-instance" xmlns:aaa="http:SLASHSLASHwww.aaa.org/aaa" xsi:schemaLocation="http:SLASHSLASHwww.aaa.org/aaa aaa.ecore">
<node>
<bbb:somethingFromBBB>xx</somethingFromBBB>
</node>
</aaa:DocumentRoot>
Notice, that there is a namespace qualifier given for elements from the other Ecore model BBB (or xsd file).
I want this, because this xmi file to be compatible to the xsd files I initially started with. And I want to validate the xmi file.
But this is not what I get, instead I get
<node>
<somethingFromBBB>xx</somethingFromBBB>
</node>
</aaa:DocumentRoot>
The xsd files look like
aaa.xsd:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xs:schema xmlns:xs="http:SLASHSLASHwww.w3.org/2001/XMLSchema"
targetNamespace="http:SLASHSLASHwww.aaa.org/aaa"
xmlns:bbb="http:SLASHSLASHwww.bbb.org/bbb">
<xs:import namespace="http:SLASHSLASHwww.bbb.org/bbb"/>
<xs:element name="node">
<xs:complexType>
<xs:choice minOccurs="0" maxOccurs="unbounded">
<xs:element ref="bbb:something_from_BBB" />
</xs:choice>
</xs:complexType>
</xs:element>
</xs:schema>
bbb.xsd:
<xsd:schema xmlns:bbb="http:SLASHSLASHwww.bbb.org/bbb" xmlns:xsd="http:SLASHSLASHwww.w3.org/2001/XMLSchema"
targetNamespace="http:SLASHSLASHwww.bbb.org/bbb"
elementFormDefault="qualified"
attributeFormDefault="unqualified">
<xsd:import schemaLocation="aaa.xsd" namespace="http://www.aaa.org/aaa"/>
<xsd:element name="something_from_BBB" type="xsd:string"/>
</xsd:schema>
The options used for saving and loading are:
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA_LOCATION, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
What am I doing wrong? What is the right way? Is this behaviour even possible? Am I totally on the wrong track?
Thank you very much for an answer!
Daniel
Re: Howto use xsd2Ecore so that the xmi-files can be validated with xsd? [message #743186 is a reply to message #743162] |
Fri, 21 October 2011 07:54 |
Ed Merks Messages: 33147 Registered: July 2009 |
Daniel,
Comments below.
On 21/10/2011 9:25 AM, daniel.engelhardt wrote:
> Hello,
> <node>
> </node>
> </aaa:DocumentRoot>
Without an xmlns for bbb?
XMI serializations won't be compatible with the XSD. You need to use
the generated resource factory to create resources that do the proper
XML serialization. That's not supported for dynamic models.
> <node>
> </node>
> </aaa:DocumentRoot>
Yes, I'd expect that from an XMI serialization.
> aaa.xsd:
> <xs:complexType>
> </xs:choice>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> bbb.xsd:
> </xsd:schema>
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
You mentioned creating a dynamic instance. That doesn't use generated
code at all.
> on the wrong track?
If you use the generated resource factory to create the resource it
should work a lot better...
> Best regards,
> Daniel
Ed Merks
Re: Howto use xsd2Ecore so that the xmi-files can be validated with xsd? [message #743191 is a reply to message #743186] |
Fri, 21 October 2011 07:57 |
Daniel,
Note that my comment about what's not supported for dynamic models
should really say that's not supported when creating dynamic instances
using the Ecore editor. It is supported for dynamic models, you but
it's clear you're using an XMIResourceImpl not an XMLResourceImpl for
the serialization to get what you've shown...
On 21/10/2011 9:54 AM, Ed Merks wrote:
> Daniel,
> Comments below.
>> Hello,
>> <node>
>> </node>
>> </aaa:DocumentRoot>
>> <node>
>> </node>
>> </aaa:DocumentRoot>
>> aaa.xsd:
>> <xs:complexType>
>> </xs:choice>
>> </xs:complexType>
>> </xs:element>
>> </xs:schema>
>> bbb.xsd:
>> </xsd:schema>
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
> code at all.
>> on the wrong track?
>> Best regards,
>> Daniel
Ed Merks
Current Time: Tue May 14 05:28:33 GMT 2024
Powered by FUDForum. Page generated in 0.02964 seconds
