Home » Language IDEs » PHP Development Tools (PDT) » Code completion not working anymore on 1.03
Code completion not working anymore on 1.03 [message #81330] Tue, 07 October 2008 09:48 Go to next message
I'm using Eclipse 3.3.2 with last PDT 1.03 and code completion just
stopped working (it do nothing anymore when I press Ctrl-Space as used to
do before.)
Any ideas in how to make it work again? I checked .metadata/.log files and
is only producing the following error message when Eclipse starts:
!MESSAGE Skipping builder 'org.eclipse.dltk.core.scriptbuilder' for
project 'xxxxxxx'. Either the builder is missing from the install, or it
belongs to a project nature that is missing or disabled.
That I think is not related with my problem.
Kind regards
defranco
Re: Code completion not working anymore on 1.03 [message #81763 is a reply to message #81330] Sun, 12 October 2008 02:58 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
PDT 1.0.3 shouldn't require DLTK. Are you sure you're not running 2.0?
Requirements are listed here:
http://www.eclipse.org/pdt/downloads/
Have you tried running an all-in-one, with JDK 5.0 or later?
Nick
defranco wrote:
> to do before.)
> and is only producing the following error message when Eclipse starts:
> Kind regards
> defranco
Re: Code completion not working anymore on 1.03 [message #82370 is a reply to message #81763] Mon, 20 October 2008 12:55 Go to previous message
It worked after installing JDK,
Tahnk You!!
Previous Topic:PDT and Galileo
Next Topic:[PDT 1.0.3] Completion code doesn't work on a new project ?
Current Time: Sat Jul 12 16:54:39 EDT 2025
Powered by FUDForum. Page generated in 0.03509 seconds
