Home » Archived » M2M (model-to-model transformation) » [ATL] (bug?) ATLEMFModelHandler throwing NPE
[ATL] (bug?) ATLEMFModelHandler throwing NPE [message #81329] Thu, 15 May 2008 09:41 Go to next message
Originally posted by: r.c.ladan.tue.nl
I get the following backtrace when setting the ATL model handler:
AtlEMFModelHandler:: getting resource
AtlEMFModelHandler:: got resource: null
SEVERE: null
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:334)
at org.eclipse.m2m.atl.engine.AtlEMFModelHandler.<init>(AtlEMFModelHandler.java:216)
at org.eclipse.m2m.atl.engine.AtlModelHandler.getDefault(AtlMod elHandler.java:61)
at meta.custom.Transform.doATLTransformation(Transform.java:97)
> Transform.java:97: this.amh = AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
with amh declared as "private AtlModelHandler amh"
This is with todays ATL. Should I file a bug report?
Rene
Re: [ATL] (bug?) ATLEMFModelHandler throwing NPE [message #81345 is a reply to message #81329] Thu, 15 May 2008 10:13 Go to previous messageGo to next message
Rene Ladan a écrit :
> SEVERE: null
> java.lang.NullPointerException
> at
> at
> at
The error seems to come from the model you're trying to load, after
setting the modelhandler (but I may be wrong).
Could you please attach your (latest) Transform.java file, and if
possible, the sample you're using (models, transformation).
Otherwise, some examples of programmatic launch can be found here :
- ATL non-regression tests :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/tests/org.eclipse.m2m.atl.tests/?root=Model ing_Project
- ATL examples :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/examples/org.eclipse.m2m.atl.examples/src/o rg/eclipse/m2m/atl/examples/?root=Modeling_Project
William
> Rene
Re: [ATL] (bug?) ATLEMFModelHandler throwing NPE [message #81363 is a reply to message #81345] Thu, 15 May 2008 10:36 Go to previous messageGo to next message
--------------040000070301020307000107
William Piers wrote:
> Hello,
> Rene Ladan a
Re: [ATL] (bug?) ATLEMFModelHandler throwing NPE [message #81377 is a reply to message #81363] Thu, 15 May 2008 11:49 Go to previous messageGo to next message
I didn't reproduce it exactly but I saw that a dependency is indirectly
required by the EMF model handler, org.eclipse.emf.ecore.xmi .
If it doesn't work, could you please report a new bug ?
Thank in advance
William
>> Hello,
>>> Hi,
>>> SEVERE: null
>>> at
>>> at
>>> at
> But the offending statement is before any (meta)model is loaded (?)
> I've attached my latest Transform.java (it acts as a bridge between ATL
> and the rest of the tool) and the metamodel. The model itself might be
> contain NDA'd stuff (who invented them? >:( ), so it is not attached.
> Rene
Re: [ATL] (bug?) ATLEMFModelHandler throwing NPE [message #81416 is a reply to message #81377] Fri, 16 May 2008 03:14 Go to previous messageGo to next message
According to the "About Plug-ins" window I have org.eclipse.emf.ecore.xmi
v2.3.2 200802051830 installed. Both 2.3.1-200709252135.jar and
2.3.2-200802051830.jar are in the plugins directory.
I'll do that.
Rene
>>> Hello,
>>>> Hi,
>>>> SEVERE: null
>>>> at
>>>> at
>>>> at
>> Regards,
>> Rene
Re: [ATL] (bug?) ATLEMFModelHandler throwing NPE [message #81620 is a reply to message #81416] Mon, 19 May 2008 04:50 Go to previous message
>> indirectly required by the EMF model handler, org.eclipse.emf.ecore.xmi .
> I'll do that.
Actually this is not needed, because it was triggered by some environmental
issue which causes Eclipse unable to find ATL-0.2.ecore (I think there are
archives on this). I'm now testing ATL 2.0.0v20080505 with Eclipse 3.4M7/EMF 2.4M7.
Rene
Previous Topic:[ATL] Packaging bug in org.eclipse.m2m.atl.engine.vm plugin
Next Topic:[ATL] I need to get a org.eclipse.m2m.atl.adt.editor Java Files!
Current Time: Fri Jul 18 07:34:20 EDT 2025
Powered by FUDForum. Page generated in 0.07968 seconds
