Home » Archived » BIRT » Cvs Birt repository but it was not a succes
Cvs Birt repository but it was not a succes [message #81232] Sat, 15 October 2005 12:10 Go to next message
Hello team,
I try to download Cvs Birt repository but it was not a succes.
Login step is Ok :
cvs -d C:\DevCvs -z3 -d:pserver:anonymous@dev.eclipse.org:/home/birt login
Logging in to :pserver:anonymous@dev.eclipse.org:2401:/home/birt
***** CVS exited normally with code 0 *****
But checkout is so bad.
cvs -d c:\CvsDev\ -z3 -d:pserver:anonymous@dev.eclipse.org:/home/birt co -P
birt
cvs server: cannot find module `birt' - ignored
***** CVS exited normally with code 1 *****
What is wrong ?
ML
Re: Cvs Birt repository but it was not a succes [message #81600 is a reply to message #81232] Mon, 17 October 2005 16:15 Go to previous message
Michel,
Take a look at
http://www.eclipse.org/birt/index.php?page=build/build_instr .html
I checked out one folder and the following command was used.
cvs co -d "org.eclipse.birt" -P -A "/source/org.eclipse.birt"
Jason Weathersby
BIRT PMC
"Michel Landrain" <m.landrain@wanadoo.fr> wrote in message
news:dir9me$drc$1@news.eclipse.org...
> Hello team,
> Login step is Ok :
> co -P
> birt
> What is wrong ?
> Regards
> ML
Previous Topic:How do you set up configuration variables or library variables ?
Next Topic:The output format pdf is not supported
Current Time: Mon Jul 14 22:16:42 EDT 2025
Powered by FUDForum. Page generated in 0.05054 seconds
