Error deploying service (NullPointer Exception) [message #81230] |
Tue, 08 March 2005 07:45  |
Originally posted by: andrej.krevl.guest.arnes.si
Good day,
I was going through the "Bottom Up Web Service Tutorial" and I always seem
to get this error message when trying to deploy the service to Tomcat:
IWAB0489E Error when deploying Web service to Axis runtime
I'm running Tomcat 4.1.31 (got same error on 5.0), Axis 1.1, Eclipse 3.1M5
and JDK 1.5.0_01.
In fact, the service gets deployed and if I create a client by using the
"Web Service Client Tutorial" I can access the webservice without a
problem.
Any ideas on what could be the problem would be highly appreciated.
andrej.
Re: Error deploying service (NullPointer Exception) [message #81839 is a reply to message #81397] |
Thu, 10 March 2005 04:19  |
Originally posted by: francisco.torres.mobipay.es
Thanks Paolo, I'm going to install all from the start one more time :-O
Paolo Di Tommaso wrote:
> I've had the same problem with JDK 1.5 and I've fixed switching to JDK 1.4.1
> You have to launch Eclipse with jdk 1.4 not just use it to compile within
> the environment ..
> I hope this can help.
> Paolo
>> Hi Andrej
>> I've the same problem with Tomcat 5.5 and JDK 1.5. I've changed to Tomcat
>> 4.1.31, Axis 1.1 with Eclipse 3.1M5 and JDK 1.4.2_07 and still the same
>> error...
>> I'm going sightly mad!!
>> Any suggestion??
>> Thanks a lot
>> > Good day,
> seem
>> > java.lang.NullPointerException
> 3.1M5
>> > and JDK 1.5.0_01.
>> > problem.
>> > Regards,
>> > andrej.
FUDForum. Page generated in 0.05577 seconds
