Home » Language IDEs » ServerTools (WTP) » Error deploying service (NullPointer Exception)
Error deploying service (NullPointer Exception) [message #81230] Tue, 08 March 2005 07:45 Go to next message
Originally posted by: andrej.krevl.guest.arnes.si
Good day,
I was going through the "Bottom Up Web Service Tutorial" and I always seem
to get this error message when trying to deploy the service to Tomcat:
IWAB0489E Error when deploying Web service to Axis runtime
I'm running Tomcat 4.1.31 (got same error on 5.0), Axis 1.1, Eclipse 3.1M5
and JDK 1.5.0_01.
In fact, the service gets deployed and if I create a client by using the
"Web Service Client Tutorial" I can access the webservice without a
problem.
Any ideas on what could be the problem would be highly appreciated.
andrej.
Re: Error deploying service (NullPointer Exception) [message #81245 is a reply to message #81230] Tue, 08 March 2005 08:30 Go to previous messageGo to next message
> java.lang.NullPointerException
> and JDK 1.5.0_01.
*snip*
It appears that it's working just fine with JDK 1.4.2. Anyone got a clue
why this happens?
Has anyone had any success with Tomcat 5.5 and JDK 1.5.0_01?
andrej.
Re: Error deploying service (NullPointer Exception) [message #81286 is a reply to message #81230] Tue, 08 March 2005 10:10 Go to previous messageGo to next message
Originally posted by: francisco.torres.mobipay.es
Hi Andrej
I've the same problem with Tomcat 5.5 and JDK 1.5. I've changed to Tomcat
4.1.31, Axis 1.1 with Eclipse 3.1M5 and JDK 1.4.2_07 and still the same
error...
I'm going sightly mad!!
Any suggestion??
Thanks a lot
> Good day,
> and JDK 1.5.0_01.
> problem.
> andrej.
Re: Error deploying service (NullPointer Exception) [message #81397 is a reply to message #81286] Tue, 08 March 2005 14:21 Go to previous messageGo to next message
Originally posted by: paolodt.yahoo.com
I've had the same problem with JDK 1.5 and I've fixed switching to JDK 1.4.1
You have to launch Eclipse with jdk 1.4 not just use it to compile within
the environment ..
I hope this can help.
Paolo
> Hi Andrej
> error...
> Any suggestion??
> Thanks a lot
> > Good day,
seem
3.1M5
> > and JDK 1.5.0_01.
> > problem.
> > Regards,
> > andrej.
Re: Error deploying service (NullPointer Exception) [message #81839 is a reply to message #81397] Thu, 10 March 2005 04:19 Go to previous message
Thanks Paolo, I'm going to install all from the start one more time :-O
> the environment ..
> Paolo
>> Hi Andrej
>> error...
>> Any suggestion??
>> Thanks a lot
>> > Good day,
> seem
> 3.1M5
>> > and JDK 1.5.0_01.
>> > problem.
>> > Regards,
>> > andrej.
Previous Topic:context parameters
Next Topic:external libs
Current Time: Thu Jul 10 01:51:02 EDT 2025
Powered by FUDForum. Page generated in 0.05896 seconds
