Home » Language IDEs » Java Development Tools (JDT) » Classpath problem?
Classpath problem? [message #81226] Tue, 29 July 2003 05:20 Go to next message
Originally posted by: hoofpatje.hotmail.com
I am starting to use Eclipse as development environment for Java, but I get
following error when compiling a simple Java program:
Error occurred during initialization of VM
java/lang/NoClassDefFoundError: java/lang/Object
I have installed Java 2 runtime environment and SDK.
What is wrong? All help very much appreciated.
Ho do I set the classpath variable correctly?
Patrick
Re: Classpath problem? [message #81418 is a reply to message #81226] Tue, 29 July 2003 10:50 Go to previous messageGo to next message
Originally posted by: amanaval.sybase.com
Right click on your project, go to the properties - JavaBuildPath and check
if you have JRE system library. If not ( I am sure its not ), click on
AddLibrary button and choose the JRE system library.
-Anou
"Patrick Vanhoof" <hoofpatje@hotmail.com> wrote in message
news:bg5e8i$kpk$1@eclipse.org...
get
> Patrick
Re: Classpath problem? [message #81749 is a reply to message #81418] Wed, 30 July 2003 05:15 Go to previous message
Anou,
Tha nks for your help. However... I select my project properties and the
Java Build Path settings. Under the Libraries tab there is one library,
JRE_LIB which refers to the rt.jar under my j2re installation.
Still I can't get it to work.
Patrick
check
> -Anou
> > Hi,
> get
> > Patrick
Previous Topic:API for setting a project's javadoc location
Next Topic:How I want to refresh local programmatically
Current Time: Fri Jul 18 03:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.27838 seconds
