Home » Eclipse Projects » Eclipse Platform » List of all extensions correct syntax and all combinations of actions
List of all extensions correct syntax and all combinations of actions [message #81125] Tue, 24 June 2003 04:20 Go to next message
Hello group. I'd be happy to find list of all possible extansions corret
syntax, the actions that they can be involve at and real explanation for
each.
Example: I have TreeViewer which I want to make it automaticaly open
whenever *.xml files located under project form type i defined in my Plugin
is being clicked or double clicked in the ResourcesNavigator ?
sorry but Readme example and "Platfor Plug-in Developers Guide (Programers
Guide).PDF" are not enough for me to know how to code such things.
Many thanks,
Asaf.
Re: List of all extensions correct syntax and all combinations of actions [message #89885 is a reply to message #81125] Mon, 07 July 2003 05:19 Go to previous message
finally found, the right place to be:
http://dev.eclipse.org/help21/index.jsp?topic=/org.eclipse.p latform.doc.isv/reference/extension-points/org_eclipse_ui_st artup.html
"Asaf" <asafr@cerylion.net> wrote in message
news:bd8u6u$326$1@rogue.oti.com...
> each.
Plugin
(Programers
> Many thanks,
> Asaf.
Previous Topic:exception from xerces when trying "Creating a HelloWorld plugin" in 2.1.0 and 2.1.1
Next Topic:CVS problems with java.net
Current Time: Tue Jul 22 01:49:01 EDT 2025
Powered by FUDForum. Page generated in 0.05457 seconds
