Re: Qooxdoo's AutoGenerated IDs [message #81463 is a reply to message #81430] |
Fri, 04 April 2008 10:19  |
Benny,
> Ok, the advantage of the Ids generated by RAP is that they refer to
> widgets as you know them. So it refers to a composite, a tree widget or
> a button.
> If you'd use the qooxdoo ids you need to care about several things:
> a) qooxdoo widgets have other names then swt widgets (they get mapped by is)
> b) some swt widgets are created by composition of existing widgets. eg.
> a swt tree = a qooxdoo layout with an inner tree.
> This would make writing tests much more difficult.
Your explanation above sounds scary.
> The question you mentioned is hard to answer. But Ralf is true that it
> could be the TextSizeDetermination which causes this inconsistency. I'm
> not sure at the moment if we can do anything here. if this a real
> blocker for you, open a bug. But I can't guarantee that we will fix this
> or be able to fix it in a nice way.
I was wondering if other RAP users ever have similliar problem with me or
maybe they have workaround on this ?
In Bugzilla we have Framework for Unit Tests request here :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154514
Does RAP team already have plan to address it ?
Best Regards,
Setya
FUDForum. Page generated in 0.37339 seconds
