Convert existing Swing proj to use VE [message #81060] |
Mon, 21 February 2005 11:19  |
Hi all,
Is it possible to take a Swing project written without using VE, and
convert it to be picked up by VE?
What are the annotations / settings needed to be set in the java file.
I.E. //@jve:???
Would that be enough?
Is there an automatic way to VE-ise an existing app?
Many thanks,
Fintan
Re: Convert existing Swing proj to use VE [message #81075 is a reply to message #81060] |
Mon, 21 February 2005 11:46  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Please look in the Help under "Using the visual editor for
Java"->Editing Java in the Visual Editor->About the visual editor for
Java->Source code generation in the visual editor->Source code generated
and parsed by the visucal editor.
Fintan wrote:
> Hi all,
> I.E. //@jve:???
> Many thanks,
> Fintan
Rich Kulp
Re: Convert existing Swing proj to use VE [message #605483 is a reply to message #81060] |
Fintan wrote:
> Hi all,
> I.E. //@jve:???
> Many thanks,
> Fintan
Rich Kulp
FUDForum. Page generated in 0.02477 seconds
