[ATL] Problem with superimposition [message #81053] |
Thu, 08 May 2008 05:52  |
I tried to use superimposition as a workaround for problems with
rifining (http://bugs.eclipse.org/230415).
So I followed the instructions on the Wiki
(http://wiki.eclipse.org/ATL_Superimposition), but I always get the same
error-message:
SCHWERWIEGEND: Pattern not equal for execution environment and module in
main (getasm != load 0 @ 0)
org.eclipse.m2m.atl.engine.AtlSuperimposeModule$AtlSuperimpo seModuleException:
Pattern not equal for execution environment and module in main (getasm
!= load 0 @ 0)
org.eclipse.m2m.atl.engine.AtlSuperimposeModule.mainSanityCr ossCheck(AtlSuperimposeModule.java:101)
The asm-file of the superimposed module starts with
<?xml version = '1.0' encoding = 'ISO-8859-1' ?>
<asm name="0">
It does not matter which rules the superimposed ATL-module contains. I
use Eclipse 3.3 with ATL 2.0.0.
Did I miss to configure something?
Greetings,
Max
FUDForum. Page generated in 0.03534 seconds
