Home » Archived » Test and Performance Tools Platform (TPTP) » NPE when launching test with Line Coverage enabled
NPE when launching test with Line Coverage enabled [message #81012] |
Thu, 17 August 2006 13:08  |
I've installed the Line coverage plugin. When the test is launched, I'm
getting an exception shortly after the new workbench window is displayed. I
don't see any of my code on the stack trace, so I'm not sure what is going
wrong.
Environment:
Eclipse 3.2
WTP 1.5
Shown below:
1. stack trace
2. java code that launches the test (sorry about the lack of indents)
Is this supposed to work?
Any suggestions?
Does this need a bug report?
Michael Giroux
Exception in thread "WorkbenchTestable" org.eclipse.swt.SWTException: Failed
to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:178)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:28)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:3763)
org.eclipse.ui.internal.testing.WorkbenchTestable.runTest(Wo rkbenchTestable.java:109)
org.eclipse.pde.internal.junit.runtime.UITestApplication.run Tests(UITestApplication.java:103)
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.NullPointerException
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence. <init>(JUnit3TestReference.java:57)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r.loadTests(JUnit3TestLoader.java:61)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
org.eclipse.pde.internal.junit.runtime.UITestApplication$1.r un(UITestApplication.java:105)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.pde.internal.junit.runtime.UITestApplication.run (UITestApplication.java:45)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
void launchTest(IFile selection) {
String method = me + ".launchTest";
tp.ctrace(method);
tp.atrace(method, "selection path: " + selection.getFullPath());
tp.atrace(method, "selection project: " + selection.getProject().getName());
BSOATestReportPlugin plugin = BSOATestReportPlugin.getDefault();
String state = plugin.getStateLocation().toFile().getPath();
ILaunchManager manager = DebugPlugin.getDefault().getLaunchManager();
ILaunchConfigurationType configType =
manager.getLaunchConfigurationType("org.eclipse.pde.ui.JunitLaunchConfig ");
String pkg = id.substring(0, id.lastIndexOf('.'));
String launchConfigName = pkg + ".JUnitLaunchConfig";
String projectName = selection.getProject().getName();
String projectRoot = selection.getProject().getLocation().toString();
tp.atrace(method, "Project Root: " + projectRoot);
try {
ILaunchConfigurationWorkingCopy wc = configType.newInstance(null,
launchConfigName );
wc.setAttribute("org.eclipse.jdt.launching.MAIN_TYPE",
"com.bull.eclipse.junit.TestDriver");
wc.setAttribute("location0",getLaunchWorkspace());
wc.setAttribute("clearws", true);
wc.setAttribute("askclear", true);
wc.setAttribute("includeOptional", true);
wc.setAttribute("default", true);
wc.setAttribute("useDefaultConfig", true);
wc.setAttribute("org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER ",
"org.eclipse.pde.ui.workbenchClasspathProvider");
// TestDriver obtains configuration from our <statelocation>/TestSuite.xml
String vmargs = "\"-Dcom.bull.eclipse.junit.CONFIG=" + state + "\"";
// and the test cases need to know the root folder for the Level 2 Test
project.
vmargs = vmargs + " \"-Dcom.bull.eclipse.junit.PROJECT_ROOT=" + projectRoot
wc.setAttribute("vmargs", vmargs);
// TODO create project in target workspace
wc.setAttribute("org.eclipse.jdt.launching.PROJECT_ATTR", projectName);
ILaunchConfiguration config = wc.doSave();
ILaunch launch = config.launch(ILaunchManager.RUN_MODE, null);
tp.atrace(method, "test launched");
} catch (CoreException e) {
tp.atrace(method, "Launch Failed: " + e.toString());
BSOATestReportPlugin.logError("Launch Failed", e);
MessageDialog.openError(null, "BSOA JUnit Plug-in Test", "Launch Failed: " +
e);
e.printStackTrace();
tp.etrace(1,method);
Re: NPE when launching test with Line Coverage enabled [message #81177 is a reply to message #81012] |
Fri, 18 August 2006 10:52   |
What java version are you using ?
"Michael Giroux" <michael.giroux@bull.com> wrote in message
news:ec27q3$k35$1@utils.eclipse.org...
> I don't see any of my code on the stack trace, so I'm not sure what is
> going wrong.
> Environment:
> Eclipse 3.2
> WTP 1.5
> Shown below:
> 1. stack trace
> Any suggestions?
> Michael Giroux
> Failed to execute runnable (java.lang.NullPointerException)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> tp.ctrace(method);
> try {
> launchConfigName );
> project.
> projectRoot + "\"";
> + e);
Current Time: Wed Jul 23 08:51:52 EDT 2025
Powered by FUDForum. Page generated in 0.05957 seconds
