Home » Archived » Maven Integration (M2E) » Artifact sources in debug mode
Artifact sources in debug mode [message #7225] Tue, 20 May 2008 05:07 Go to next message
Hi there,
I have several projects in workspace linked via maven (with help of
m2eclipse). All works fine, but when I try to debug one of the projects
I can't fall to source from another project, so I need to add them as
source attachment as usual. I think it would be great to make support
for including artifact sources in debug mode as well.
Re: Artifact sources in debug mode [message #7252 is a reply to message #7225] Tue, 20 May 2008 09:23 Go to previous message
Originally posted by: igor.ifedorenko.com
Sergey Elin wrote:
> Hi there,
I have not heard about this problem, source lookup works for both
workspace projects and artifacts from remote repositories (after I
right-click on artifacts or projects and invoke Maven->Download sources
of course).
Can you please open bug report in JIRA
http://jira.codehaus.org/browse/MNGECLIPSE with sample projects and
steps to reproduce the problem? Make sure to note exact m2eclipse
version you're using.
Igor
Previous Topic:m2eclipse 0.9.4.20080516-1145 weekly build is posted
Next Topic:Working Set in create maven project dialog
Current Time: Fri Jul 18 22:31:57 EDT 2025
Powered by FUDForum. Page generated in 0.03879 seconds
