Home » Language IDEs » ServerTools (WTP) » Creating J2EE Web Project fails
Creating J2EE Web Project fails [message #80852] |
Mon, 07 March 2005 05:40  |
Originally posted by: per.implior.com
When I try to create a new 'J2EE Web Project', the wizard dialog box shows
the error message 'There are no available target servers.'
What exactly does that mean?
Also, when I try to define a 'New Server Runtime', the 'Next' button is
shown, but when I click on it, absolutely noting happes. What's wrong?
I'm running Tomcat 5 on a WinXP box, and I have tried to install WTP into
Eclipse, including all the prerequisites. (That was extremely hairy --
Eclipse is in dire need of a better model for packaging 'features' so that
all prerequisites are included.)
Per Lindberg
Re: Creating J2EE Web Project fails [message #81358 is a reply to message #81332] |
Tue, 08 March 2005 12:20   |
Originally posted by: alberto.juez.gmail.com
Hi!
mi name is Alberto Juez and I have the same problem as Per.
I'm using the instructions included in the developerWorks tutorial "Build
a database-enabled action Web service", and I have the following problems:
1.- When I try to make a new "Dynamic Web Project", I have to define a new
server. After that, I push the "New..." button next to the Target Server
Definition. Then I select one of the different options avalaible (Tomvat
5.0 / 5.5, ...) and when I press "Next", nothing happens (you're right in
your message)
2.- If I try to define the New Target Server through "Window ->
Preferences -> Server -> Installed Runtimes" I get this error message:
"The currently displkayed page contains invalid values"
I'm using "Eclipse Web Tooling Platform Contribution - IBM" version 1.0M3
If you want more information, feel free to send me an e-mail
Thanks!
Alberto Juez
Jason Sholl wrote:
> A target server is required so the proper jars can be added to your new
> J2EE Web Project. The server target combo is driven from the servlet
> version selection. Try clicking the New... button next to the target
> server combo. This will bring up another wizard in which you can create
> a new server target. Is this where you said the next button wasn't working?
>> shows the error message 'There are no available target servers.'
>> into Eclipse, including all the prerequisites. (That was extremely hairy
>> -- Eclipse is in dire need of a better model for packaging 'features' so
>> that all prerequisites are included.)
>> Cheers,
>> Per Lindberg
Re: Creating J2EE Web Project fails [message #81413 is a reply to message #81358] |
Tue, 08 March 2005 16:39   |
Sounds like there is a bug here. Could you please open a bugzilla for
this: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols
Alberto Juez wrote:
> Hi!
> "Build a database-enabled action Web service", and I have the following
> problems:
> new server. After that, I push the "New..." button next to the Target
> Server Definition. Then I select one of the different options avalaible
> (Tomvat 5.0 / 5.5, ...) and when I press "Next", nothing happens (you're
> right in your message)
> Thanks!
> Alberto Juez
>> new J2EE Web Project. The server target combo is driven from the
>> servlet version selection. Try clicking the New... button next to the
>> target server combo. This will bring up another wizard in which you
>> can create a new server target. Is this where you said the next
>>> is shown, but when I click on it, absolutely noting happes. What's
>>> wrong?
>>> hairy -- Eclipse is in dire need of a better model for packaging
>>> 'features' so that all prerequisites are included.)
>>> Cheers,
>>> Per Lindberg
Re: Creating J2EE Web Project fails [message #82103 is a reply to message #81413] |
Thu, 10 March 2005 10:14  |
Thanks, Jason, but I've discovered that version 1.0M3 requires Eclipse 3.1.
With these versions everything works OK!
Sorry for the inconvenience (and about my English)
Thanks!
Alberto Juez
> Alberto Juez wrote:
>> Hi!
>> problems:
>> Thanks!
>> Alberto Juez
>>>> wrong?
>>>> Cheers,
>>>> Per Lindberg
Current Time: Thu May 08 03:31:15 EDT 2025
Powered by FUDForum. Page generated in 0.06901 seconds
