Home » Eclipse Projects » Eclipse Platform » build.xml for plugins needing customization
build.xml for plugins needing customization [message #80779] Mon, 23 June 2003 11:57 Go to next message
Originally posted by: pilgrim.us.ibm.com
if i do 'create plugin jars' from my plugin's plugin.xml file, it
generates a build.xml.
the generated build.xml needs some tweaks in my case. what's the best
way to do this - a separate xml file so it doesn't get overwritten, call
out to that xml file from build.xml and reenter that call every time the
build.xml file is generated?
examples of what i need to do:
- call rmic on several classes
- create multiple jars from my source directory by package
- use a custom manifest with the jar command so that some classes are
tagged as beans
jeff
Re: build.xml for plugins needing customization [message #82678 is a reply to message #80779] Wed, 25 June 2003 20:23 Go to previous message
Originally posted by: pascal_rapicault.yahoo.fr
As a start I would use a generated build.xml file that I would then modify.
To avoid the file to be overriden on generation set custom=true in
build.properties.
For your case of multiple jar, you may consider each jar content in a
separate source directory and add the appropriate line in the
build.properties.
If you think more flexibility should/can/must be added, enter a PR.
PaScaL
"Jeff Pilgrim" <pilgrim@us.ibm.com> a
Previous Topic:Possible Ant bug in M1?
Next Topic:TableViewer - Editing and ComboBox
Current Time: Sun Aug 31 01:58:08 EDT 2025
Powered by FUDForum. Page generated in 0.02693 seconds
