Border usage [message #80671] |
Fri, 23 May 2003 09:38  |
Is it possible to create a border that is a combination of lines and some
shapes for a figure? Below is an example of a border that I would like to
create:
________________________________
|_____ /\_________ _ _ ____/\____|
------>/__\ \/----->
The arrow to the triangle and from the diamond indicate that a
connection could exist from another element to the border and/or from the
border to another element.
Re: Border usage [message #80745 is a reply to message #80671] |
Fri, 23 May 2003 10:38  |
------=_NextPart_000_0053_01C32117.6191DEE0
Content-Type: text/plain;
charset="iso-8859-1"
It would be nice if we could define the metaphor for this type of thing. =
Other IBM applications use a shape like this:
Which appear on the right or left side. It is the same shape in either =
case, but for outgoing the "tip" is pointed outside the shape.
Remember that a figures bounds has to encompass everything that will be =
painted. So, your bounds will be slightly larger than the box around =
the figure, since the shape hangs outside of the box. If you don't like =
where selection handles end up as a result of this, implement the =
interface HandleBounds.
"AK" <akatti@ca.ibm.com> wrote in message =
news:bal884$khg$1@rogue.oti.com...
>=20
> Is it possible to create a border that is a combination of lines and =
some
> shapes for a figure? Below is an example of a border that I would like =
to
> create:
>=20
>=20
> connection could exist from another element to the border and/or from =
the
> border to another element.=20
> =20
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2723.2500" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>It would be nice if we could define the =
metaphor=20
for this type of thing. Other IBM applications use a shape like=20
this:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3D"Courier New" size=3D2>+-----\</FONT></DIV>
<DIV><FONT face=3D"Courier New" size=3D2>| =
\</FONT></DIV>
/</FONT></DIV>
<DIV><FONT face=3D"Courier New" size=3D2>+-----/</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Which appear on the right or left =
side. It is=20
the same shape in either case, but for outgoing the "tip" is pointed =
outside the=20
shape.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Remember that a figures bounds has to =
encompass=20
everything that will be painted. So, your bounds will be slightly =
larger=20
than the box around the figure, since the shape hangs outside of the =
box. =20
If you don't like where selection handles end up as a result of this, =
implement=20
the interface HandleBounds.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"AK" <</FONT><A=20
href=3D"mailto:akatti@ca.ibm.com"><FONT face=3DArial=20
size=3D2>akatti@ca.ibm.com</FONT></A><FONT face=3DArial size=3D2>> =
wrote in message=20
</FONT><A href=3D"news:bal884$khg$1@rogue.oti.com"><FONT face=3DArial=20
size=3D2>news:bal884$khg$1@rogue.oti.com</FONT></A><FONT face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> Hi,<BR>> =
<BR>> Is it=20
some<BR>>=20
shapes for a figure? Below is an example of a border that I would like=20
to<BR>> create:<BR>> <BR>> =20
________________________________<BR>> =20
nbsp; & nbsp;=20
|<BR>> =20
nbsp; & nbsp;=20
|<BR>> =20
nbsp; & nbsp;=20
|<BR>> |_____ /\_________ _ _ ____/\____|<BR>> =
------>/__\ &a mp;nbsp;  =
;   ;=20
\/-----><BR>> <BR>> The arrow to the triangle and =
from the=20
diamond indicate that a<BR>> connection could exist from another =
element to=20
the border and/or from the<BR>> border to another element. <BR>>=20
nbsp; & nbsp; & n=
bsp; &n bsp; =20
<BR>> </FONT></BODY></HTML>
------=_NextPart_000_0053_01C32117.6191DEE0--
FUDForum. Page generated in 0.04995 seconds
