Fixing Columns [message #7191] |
Wed, 26 July 2006 09:58  |
is it possible to set one or even more columns fixed so that they don't
move when scrolling horizontally? (something like the row headers which
can be displayed)
regards, Serge
Re: Fixing Columns [message #8021 is a reply to message #7989] |
Wed, 26 July 2006 15:17  |
I don't have any timetable for when I push out a new build. Hopefully,
Nebula will eventually get access to a build machine and that won't be
an issue.
KTable uses a different API than Grid. Grid follows the straightforward
Table API. KTable uses a more complex MVC paradigm. Other than that, I
don't know too much about KTable.
-Chris
Serge wrote:
> Hi Chris
> ok, great. how many times a month do you publish new releases? like once
> a month? looking for alternatives to the swt table i also found a table
> named ktable. what are the most significant differences between the
> nebula grid and ktable (since ktable is also a grid). when would i use
> ktable and when would i use the nebula grid?
> regards, Serge
Re: Fixing Columns [message #563458 is a reply to message #7191] |
Wed, 26 July 2006 11:28  |
Not currently, but it is the next significant feature that I plan to add.
-Chris
Serge wrote:
> Hi
> can be displayed)
> regards, Serge
Re: Fixing Columns [message #563480 is a reply to message #7264] |
Wed, 26 July 2006 14:33  |
Hi Chris
ok, great. how many times a month do you publish new releases? like once a
named ktable. what are the most significant differences between the nebula
grid and ktable (since ktable is also a grid). when would i use ktable and
regards, Serge
Re: Fixing Columns [message #563500 is a reply to message #7989] |
an issue.
-Chris
Serge wrote:
> Hi Chris
> regards, Serge
FUDForum. Page generated in 0.17283 seconds
