Home » Language IDEs » C / C++ IDE (CDT) » 'intellisense'
'intellisense' [message #80558] |
Fri, 19 September 2003 17:01  |
Originally posted by: symme7ry.MICROSOFTSfreeEMAILservice.com
I've seen previous questions asking about 'code assist' in general, but
not specifically about 'intellisense'.
When I type "string s; s.", I'd like a bunch of method signatures to pop
up after I type the period. When I type "getline(", I'd like the method
signature to pop up after I type the parenthesis. Does this particular
feature exist now? Or anything similar? I don't really care that if I type
"f" then control space enter, it fills in a for loop for me. That kind of
code assist I dont care for. I just need some sort of built-in knowledge
of the c++ library. If this does not yet exist, does anyone know when it
will?
I have eclpise version 2.1.1 and cdt version 1.2.0.51
Re: 'intellisense' [message #80616 is a reply to message #80558] |
Mon, 22 September 2003 09:40   |
Completing after a "." requires parsing the current document and knowing
the type of the variable before the ".". This is not available now for
Code Assist (release CDT 1.2, October 2003); however, it will be available
on the next release (CDT 2.0).
In this release, inside the body of a function or a method, you are able
to find completion proposals of global functions, variables, enums,
macros, etc...
Code assist is using the search feature to find these proposals. Anything
that is globally defined that starts with the given prefix will be
searched for and added as a completion proposal. This requires two things:
1- that you have the new indexer enabled ( it will be enabled by default
by the release date, but right now you have to check the "C/C++ Project"
tab for your project's properties. )
2- that your code is parsing without errors and that your code is saved.
If you have some parsing errors, you do not garantee to find all possible
proposals.
> will?
Re: 'intellisense' [message #80706 is a reply to message #80616] |
Tue, 23 September 2003 08:54   |
This is a real pity as it means that our company will not be able to use
the CDT until 2.0 comes out, ans as 2.0 will be written on eclipse 3.0 it
will be more then a year, all this to get a feature that are considered
minimum for developers. Is there an alternative?
The ast parser is already running, so it shouldn't be too hard to find out
the type or am I completely wrong here?
Anyway apart from this the CDT has really made some great steps forward.
LE
> macros, etc...
> proposals.
> > will?
Re: 'intellisense' [message #80752 is a reply to message #80706] |
Tue, 23 September 2003 11:29   |
The CDT is toolchain agnostic, which means that the parser is expected to
work for most specified compilers. Even if the compilers are ANSI compliant,
there can still be problems.
There is a huge amount of verification we need to do to get things like
STDIO.H parsing on different platforms, due to the amount of internal
compiler macro definitions. If you use gcc, for example, and do 'gcc -v',
you'll see it reads in its specs from some text file in your install that
tells the compiler what extra #defines to add and re-order the include path.
Getting this to work for Standard Make projects is very difficult given
these requirements, as we have no understanding of what toolchain is
provided. We are working quite diligently to provide solutions in the
future that will provide code assist/search/refactoring features as good as
the JDT.
JohnC
"Eli" <elil@amdocs.com> wrote in message news:bkpfqf$306$1@eclipse.org...
> LE
available
> > macros, etc...
Anything
things:
possible
> > proposals.
but
pop
method
type
of
knowledge
it
> > > will?
Re: 'intellisense' [message #80938 is a reply to message #80752] |
Wed, 24 September 2003 02:31   |
Thanks for the clarification John,
I still don't understand the full complexity, It is already possible to
define include paths and macros from within the platform, This should be
enough for a first stage (Many IDE's do that). Then plugins can then write
extentions to change these definition automaticly from the make files or
whatever they like, at least the basics will be there and writting these
plugins shouldn't be too hard as they should be written for each tool.
LE
> the JDT.
> JohnC
> > LE
> available
> > > macros, etc...
> Anything
> things:
> possible
> > > proposals.
> but
> pop
> method
> type
> of
> knowledge
> it
> > > > will?
Re: 'intellisense' [message #80982 is a reply to message #80938] |
Wed, 24 September 2003 09:03   |
Macro definitions and include path ordering can change depending on the
compiler options in GNU. Our strategy for parsing was to basically
implement the front end of a compiler, with Symbol table and scoping rules
and all of the complexity that comes from the C++ language. This, in the
long term, will yield the correct solution for complex features like
refactoring, writable DOM, search and code assist.
Regarding having extension points edit the configuration for parsing ... we
already have that. CDT is toolchain agnostic and plugins that implement that
extension point need to know specifically what tools are being used, so
that:
a) include paths/macros get set up properly on a compilation unit
granularity
b) the proper parser is discovered (via extension points) to handle that
particular flavour of C/C++, as nearly every compiler introduces its own
constructs; our experience has shown that writing one C++ parser that will
support the union of all of these C++/C variant languages does not work due
to ambiguities and complexities
We plan to set up a target model (the tool representation) post 1.2.
Feel free to send me an email if you are willing to chip in and help.
JohnC
"Eli Lopian" <elil@amdocs.com> wrote in message
news:bkrdn9$rpl$1@eclipse.org...
> LE
to
compliant,
'gcc -v',
that
path.
as
> > the JDT.
> > JohnC
use
it
considered
out
forward.
> > > LE
knowing
for
> > available
able
> > > > macros, etc...
> > Anything
> > things:
default
Project"
saved.
> > possible
> > > > proposals.
general,
> > but
to
> > pop
> > method
particular
if I
> > type
kind
> > of
> > knowledge
when
> > it
> > > > > will?
Re: 'intellisense' [message #81127 is a reply to message #80982] |
Thu, 25 September 2003 22:13   |
Hi,all:
Anyway, for a developer using IDE, maybe it's a killer feature when we
type a dot, the methods and attributes of the class before the dot would
list below.
For C++, parsing work may be complex, we hope CDT could add some simple
parsings for user's class members in 1.2 or later, but not very long time
for waiting.
Thanks!
Qin Feng
> that:
> granularity
> Thanks
> JohnC
> > LE
> to
> compliant,
> 'gcc -v',
> that
> path.
> as
> > > the JDT.
> > > JohnC
> use
> it
> considered
> out
> forward.
> > > > LE
> knowing
> for
> > > available
> able
> > > > > macros, etc...
> > > Anything
> > > things:
> default
> Project"
> saved.
> > > possible
> > > > > proposals.
> general,
> > > but
> to
> > > pop
> > > method
> particular
> if I
> > > type
> kind
> > > of
> > > knowledge
> when
> > > it
> > > > > > will?
Re: 'intellisense' [message #81158 is a reply to message #81127] |
Fri, 26 September 2003 13:09   |
Point taken.
JohnC
"Qin Feng" <qf0421@hotmail.com> wrote in message
news:bl07bo$ghr$1@eclipse.org...
> Hi,all:
> list below.
> for waiting.
> Thanks!
> Qin Feng
rules
we
that
> > that:
> > granularity
will
due
> > Thanks
> > JohnC
to
be
write
or
these
> > > LE
expected
> > to
> > compliant,
like
internal
> > 'gcc -v',
> > that
include
> > path.
given
the
good
> > as
> > > > the JDT.
> > > > JohnC
to
> > use
3.0
> > it
> > considered
find
> > out
> > forward.
> > > > > LE
> > knowing
now
> > for
> > > > available
are
> > able
enums,
> > > > > > macros, etc...
> > > > Anything
be
two
> > > > things:
> > default
> > Project"
is
> > saved.
> > > > possible
> > > > > > proposals.
> > general,
> > > > but
signatures
> > to
> > > > pop
the
> > > > method
> > particular
that
> > if I
> > > > type
That
> > kind
> > > > of
> > > > knowledge
know
> > when
> > > > it
> > > > > > > will?
Re: 'intellisense' [message #81423 is a reply to message #80982] |
Tue, 30 September 2003 12:40  |
> that:
> granularity
You've set yourself a gigantic task! I hope you're aware of GLR parser
generators like Elkhound (http://www.cs.berkeley.edu/~smcpeak/elkhound/)
that make parsing C++ a lot less daunting.
Rob
Current Time: Mon Jul 21 21:59:02 EDT 2025
Powered by FUDForum. Page generated in 0.04218 seconds
