Home » Language IDEs » Java Development Tools (JDT) » Class File Viewer- classpath problem
Class File Viewer- classpath problem [message #80535] Sat, 26 July 2003 09:55 Go to next message
If i use seperate source and output folders in a Java project and try to use
the Class File Viewer i get the message:
The classfile not on the classpath.
If i dont use separate folders then of course it works.
Should the Class File Viewer add the classpath before it executes?
Is the a vay to add the classpath by hand?
thanks
Henning
Re: Class File Viewer- classpath problem [message #81196 is a reply to message #80535] Tue, 29 July 2003 03:12 Go to previous message
Can you explain in more detail where the class file is that you want to
open and how you "use" the class file viewer?
Dani
Previous Topic:Java code manipulation
Next Topic:2.1.1 Team functionality broken
Current Time: Sun Jul 13 18:37:49 EDT 2025
Powered by FUDForum. Page generated in 0.03687 seconds
