Home » Modeling » GMF (Graphical Modeling Framework) » Request for SDO Sample with Library.xsd
Request for SDO Sample with Library.xsd [message #80483] Thu, 23 November 2006 10:57 Go to next message
Originally posted by: simon.eggler.gmx.net
Hello
I'm trying to get the hang of sdo, but haven't quite suceeded yet. what
i've done so far is:
- check out the xsd to emf to rich client editor tutorial: nice'n easy
- read the ibm article and the eclipse tutorial on how to edit a
datagraph, so far so good.
- now, what i'd like to do is transfer my emf rcp editor into an
emf/sdo/rcp editor that can read and write datagraphs instead of simple
xml models.
where did i get stuck?
- i did set all those properties needed for generating an sdo enabled
model. now, i do not know how i can properly interfere with the generated
edit/editor in order to hook up a dms???
who can help?
thank you,
simon
Re: Request for SDO Sample with Library.xsd [message #84015 is a reply to message #80483] Thu, 07 December 2006 09:28 Go to previous message
So, you're not using GMF as far as I can tell... Perhaps the EMF newsgroup
is a better place for this question?
Rich
On 11/23/06 10:57 AM, in article
6a9761020e29778171ccb83629fd85a5$1@www.eclipse.org, "Simon"
<simon.eggler@gmx.net> wrote:
> Hello
> xml models.
> who can help?
> thank you,
> simon
Previous Topic:How to assign element in getDiagramDomainElement()
Next Topic:how to get editpart for semantic element or how to select semantic element in diagram
Current Time: Tue Jul 22 14:42:18 EDT 2025
Powered by FUDForum. Page generated in 0.04137 seconds
