[ATL] Problem with matched rule and multiple source models [message #80374] |
Tue, 29 April 2008 09:13  |
I have a matched rule with multiple source models, and the problem is
that it does not get matched. The code follows:
rule init {
from
system : GenericCospel!System
to
coopnpackage: COOPNMetaModel!COOPNPackage(
name <- system.name,
ownedModules <- system.ownedTypes
rule ruleType {
from
c : COOPNMetaModel!COOPNPackage,
t : GenericCospel!Type
to
Before putting the c variable in the source of ruleType, my result was a
match between ruleType and the last line in rule init, giving me a
hierarchy (things generated by ruleType were children of things
generated by init).
After I added c, the match is not done. I suppose because the source is
different from the system.ownedTypes type.
Since I need to have that c object further in the code, is there any way
to achieve this matching?
Thanks very much in advance,
Re: [ATL] Problem with matched rule and multiple source models [message #80751 is a reply to message #80374] |
Tue, 06 May 2008 05:35  |
Luis Pedro a écrit :
> Hello,
> rule init {
> from
> to
> rule ruleType {
> from
> to
Here there is an error : you can't match output elements in the from
section. You need to refer to the corresponding input element. For
instance :
rule ruleType {
from
c : GenericCospel!System,
William
> generated by init).
FUDForum. Page generated in 0.05402 seconds
