@gmf not recognized - setup problem? [message #7174] |
Tue, 23 December 2008 07:41  |
Editing the 'filesystem' example fails with an error: "Encountered "@ gmf
package" at line... However, pure Emfatic editing seems to work properly,
including ecore model generation.
It seems as if Eugenia is not properly installed or doesn't work in my
installation at all.
Installed Software (Windows XP, SP3)
- Eclipse Ganymede 3.4.0
+ Emfatic 0.3.0.200810132307
+ Epsilon Core 0.8.3
+ Epsilon EMF/GMF Live Validation 0.8.3
+ Epsilon EMF/GMF Scripting Validation 0.8.3
+ Epsilon Eugenia 0.8.3
+ openArchitectureWare 4.3.0
+ GMF 3.4.0
among others
Plug-in Details
Eugenia Plug-in 0.8.3
Eugenia Runtime Plug-in 0.8.3
The same installation on my notebook shows the same problem, probably a
very stupid (beginner's) problem...
Re: @gmf not recognized - setup problem? [message #7303 is a reply to message #7288] |
Tue, 23 December 2008 10:02  |
One thing that is in the development queue is enabling users to
customize the produced GMF models by contributing transformations that
will be executed on top of the built-in ones. There are also plans to
add first-class support for SVG images in nodes (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=254990). Needless to say,
we are always open to any suggestions for improvement by the community -
so if you have any, we would really like to hear them!
Dimitris
Reto Weiss wrote:
> I felt like a fool, thank you for this clarification.
> Now things work fine - really cool, I like Eugenia because tweaking all
> the GMF helper models (once the are magically created) isn't a very
> straight forward approach, I fear.
> Is there any ongoing development in this (Eugenia) area? Any links about
> that?
Re: @gmf not recognized - setup problem? [message #563293 is a reply to message #7174] |
Tue, 23 December 2008 07:47  |
Hi Reto,
I assume you are getting the error in the Emfatic editor. The latest
version of Emfatic does not seem to support annotations without details.
I'd suggest you add a dummy detail as a workaround:
e.g. @gmf(foo="bar")
Dimitris
> gmf package" at line... However, pure Emfatic editing seems to work
> properly, including ecore model generation.
> + GMF 3.4.0
> among others
> Plug-in Details
Re: @gmf not recognized - setup problem? [message #563365 is a reply to message #7246] |
Tue, 23 December 2008 08:25  |
No worries. Actually, I added the sentence you found in the
troubleshooting section after I responded to your message.
Dimitris
Reto Weiss wrote:
> Yes, I just found it myself. Sorry for the inconvenience.
Re: @gmf not recognized - setup problem? [message #563388 is a reply to message #7269] |
Tue, 23 December 2008 08:46  |
Any links about that?
Re: @gmf not recognized - setup problem? [message #563407 is a reply to message #7288] |
Dimitris
> that?
FUDForum. Page generated in 0.05584 seconds
