Home » Archived » BIRT » workspace\org.eclipse.datatools.connectivity.oda does not exist
workspace\org.eclipse.datatools.connectivity.oda does not exist [message #80044] Mon, 10 October 2005 00:00 Go to next message
Hi All,
I've checked out the BIRT project from the CVS repository, however, when I
try to build the viewer, I am getting the following error saying
"workspace\org.eclipse.datatools.connectivity.oda does not exist". Is it
because this files missed while checking out or What could be the posible
problem.
[echo] start call Jar task in C:\Documents and
Settings\Daviskv\workspace\org.eclipse.datatools.connectivit y.oda
BUILD FAILED: C:\Documents and
Settings\Daviskv\workspace\org.eclipse.birt.data\BuildData.x ml:351:
Basedir C:\Documents and
Settings\Daviskv\workspace\org.eclipse.datatools.connectivit y.oda does not
exist
Thanks in advance,
Davis
Re: workspace\org.eclipse.datatools.connectivity.oda does not exist [message #80059 is a reply to message #80044] Mon, 10 October 2005 02:08 Go to previous messageGo to next message
Davis,
You have to download (checkout) datatools project now (probably)
'org.eclipse.datatools.connectivity.oda' is from datatools
peco
Davis wrote:
> Hi All,
> problem.
> exist
> Thanks in advance,
> Davis
Re: workspace\org.eclipse.datatools.connectivity.oda does not exist [message #80072 is a reply to message #80059] Mon, 10 October 2005 01:47 Go to previous messageGo to next message
Hi peco,
As suggested by you, I've checked out datatool, connectivity module. and
noticed "org.eclipse.datatools.connectivity.oda" dir is created in the
workspace location. But its still complain the same error when building
the viewer.
BUILD FAILED
C:\Documents and
Settings\Davis\workspace\org.eclipse.birt.report.viewer\Buil dViewer.xml:214:
The following error occurred while executing this line:
C:\Documents and
Settings\Davis\workspace\org.eclipse.birt.report.model\Build Model.xml:297:
C:\Documents and
Settings\Davis\workspace\org.eclipse.birt.data.oda\BuildOda. xml:194:
Settings\Davis\workspace\org.eclipse.datatools.connectivity. oda does not
exist
Total time: 4 seconds
Davis
Re: workspace\org.eclipse.datatools.connectivity.oda does not exist [message #80104 is a reply to message #80072] Mon, 10 October 2005 09:42 Go to previous messageGo to next message
Davis,
plugins in datatools are in subdirectory plugins
import all subdirectories plugins for 3 main directory of datatools
(there are about 20 plugins in datatools)
Peco
Davis wrote:
> Hi peco,
> the viewer.
> BUILD FAILED
> C:\Documents and
> C:\Documents and
> C:\Documents and
> exist
> Davis
Re: workspace\org.eclipse.datatools.connectivity.oda does not exist [message #80194 is a reply to message #80104] Tue, 11 October 2005 03:45 Go to previous messageGo to next message
Hi Peco,
I managed to compile including all the necessary jar files and packages,
but I encounter the following error while building the BuildData.xml. I
verified that the dtd file is there in the specified location. What could
be the cause ??
compileSource:
Jar:
[echo] end call Jar task in C:\Documents and
Settings\Daviskv\workspace\org.eclipse.birt.report.model
Settings\Daviskv\workspace\org.eclipse.birt.report.designer. ui\BuildDesignerUI.xml:237:
Following error occured while executing this line
C:\Documents and
Settings\Daviskv\workspace\org.eclipse.birt.report.engine\Bu ildEngine.xml:394:
C:\Documents and
Settings\Daviskv\workspace\org.eclipse.birt.data\BuildData.x ml:3: External
entity not found:
"http://jasperreports.sourceforge.net/dtds/jasperreport.dtd".
Total time: 27 seconds
Thanks for your help so far..
Davis
Re: workspace\org.eclipse.datatools.connectivity.oda does not exist [message #80237 is a reply to message #80194] Tue, 11 October 2005 11:01 Go to previous messageGo to next message
Davis,
I build datatools and birt in eclipse and export with eclipse export
I don't try last version yet, because problem with datatools (and rdb) for
me - it doesn't support postgresql (and more another databases) and oracle
support is bad, for now
try build datatools and birt in eclipse
peco
Davis wrote:
> Hi Peco,
> be the cause ??
> compileSource:
> Jar:
> C:\Documents and
> C:\Documents and
> entity not found:
> Davis
Re: workspace\org.eclipse.datatools.connectivity.oda does not exist [message #80833 is a reply to message #80237] Thu, 13 October 2005 21:55 Go to previous message
Hi Haris,
I've posted this question in the news group as separate subject, but no
body seems to be replying, hence I am writing personnaly.
I succeeded checkout the project and am trying to build it, but I got some
validation error in org.eclipse.birt.data/BuildData.xml file. I looked the
content of this file as pasted below, but doesn't make sense to me, it
refers jasperReport DTD file instead of build format. Could you please let
me know if this is correct ?. Are we using jasperReport in the BIRT
project in any ways, other than in convertors ?.
<!-- Created using an evaluation version of JasperAssistant
(http://www.jasperassistant.com) -->
<!DOCTYPE jasperReport PUBLIC "-//JasperReports//DTD Report Design//EN"
"http://jasperreports.sourceforge.net/dtds/jasperreport.dtd">
<jasperReport name="Unnamed" pageWidth="595" pageHeight="842"
columnWidth="555" leftMargin="20" rightMargin="20" topMargin="30"
bottomMargin="30">
</jasperReport>
Thanks in Advance.
Warm Regards,
Davis
Previous Topic:Unable to checkout CVS as anonymous user
Next Topic:create new grid row
Current Time: Sat Jul 26 09:22:45 EDT 2025
Powered by FUDForum. Page generated in 0.04098 seconds
