Fully resolved classpath [message #648] |
Sat, 19 April 2003 05:39  |
Originally posted by: vlad_ender.hotmail.com
I'm writing a plugin for my code analyser. It needs a full run/buildtime
classpath so that it can build the full symbol table.
Unfortunately, I can't figure out how to do it in eclipse. Some libraries
are ok (and I get the full absolute path), but for some I get just (say)
"/lib/somelib.jar". This example is when I tried it on another plugin,
which had lib/somelib.jar in its plugin directory. The IPath element
claims the path is absolute, which, with the leading "/" looks pretty
weird. I would not mind getting relative path, as long as I could have a
way of pointing my classloader in the right direction.
I don't even mention dependent projects, as that looks even worse - I
don't want to analyse the source for them (or not necessarily), I just
want the output directory and all libraries.
I'm sure there must be a way of doing it, as generating ant build file
seems to manage it ok. I wasn't able to find out what piece of code is
generating it though.
Thanks for any help,
Vlad
Re: Fully resolved classpath [message #1158 is a reply to message #648] |
Mon, 21 April 2003 11:07  |
There are internal JARs and external JARs. Internal JARs are described
by a 'workspace' path. You have to get the JAR's resource and use
'getLocation' to get the resource's external location.
IWorkspaceRoot root= ResourcesPlugin.getWorkspace().getRoot();
IResource jarFile= root.findMember(jarPath);
if (jarFile != null) {
return jarFile.getLocation();
} else {
// no workspace resource existing with the path described by jarPath
// -> must be an external JAR (or an invalid classpath)
Similar procedure to get the output location of dependend projects
IProject project= root.findMember(dependendProjectPath);
IJavaProject jProject= JavaCore.create(project);
IPath outputLocation= jProject.getOutputLocation()
Martin
Vlad Ender wrote:
> Vlad
FUDForum. Page generated in 0.03108 seconds
