Code assist in CDT 1.2.0.40: does ist work or not? [message #79962] |
Wed, 10 September 2003 07:55  |
I just installed the latest nightly build of the CDT (1.2.0.40). I
previously had the 1.1 release.
My main expectation from the 1.2.0.40 version was that the code assist
feature would be available. But somehow I m not getting it to work. The
(simple) test I do is the following:
write following c++ code:
1 int main(int argc, char** argv){
2 int a_variable;
3 //here I will do something
4 }
Then I type the character 'a' on line 3, after what I hit Ctrl+space, with
the expectation that a list containing at least
'a_variable' would popup. But what I get is the code template "author", that
happens to begin with the letter 'a'.
The CDT Documentation states that:
<cite cdt doc>
Use Content Assist to insert the following directly into your code:
a.. Elements of your project or referenced project(s)
b.. Code templates
</cite cdt doc>
What is meant with "element" in this text? In my understanding an element is
for example "a_variable" in my example code.
Thx 4 ur advice
WY
Re: Code assist in CDT 1.2.0.40: does ist work or not? [message #80115 is a reply to message #80008] |
Fri, 12 September 2003 16:37  |
Are you sure that the first Indexer checkbox (for CTAGS) is OFF?
"WY" <test@test.com> wrote in message news:bjps9a$4aa$1@eclipse.org...
> This does not work for me. I guess the indexer first need to run an build
> the index.
> And since the C/C++ search function probably goes over the indexer, I
> started a search which
> also started the indexer. But it simply runs out of memory after a
while(my
> project is very large, ~25000 files). Is there some kind of limitation
> regarding the size of projects that can be handled by the indexers?
> Thx
> WY
> "John Camelon" <jcamelon@rational.com> schrieb im Newsbeitrag
> news:bjn87h$hu0$1@eclipse.org...
> > There is a temporary checkbox you need to enable ...
> > Go to Project :: Properties :: C/C++ Project :: Indexer and check both
the
> > NEW indexer and the dependency tree checkboxes
> > Keep the CTAGS indexer checkbox unchecked.
> > Then try it out.
> > These checkboxes will be removed in the final version of 1.2, ( refer to
> Bug
> > 42865 in bugzilla) so sorry for the inconvenience.
> > JohnC
> > "WY" <test@test.com> wrote in message news:bjn3d9$cej$1@eclipse.org...
> > > Hi,
The
> > > 2 int a_variable;
> > > 4 }
> with
"author",
> > that
> > > <cite cdt doc>
> > > b.. Code templates
> > > </cite cdt doc>
> element
> > is
> > > Thx 4 ur advice
> > > WY
FUDForum. Page generated in 0.28346 seconds
