Home » Language IDEs » ServerTools (WTP) » Can the data explorer be used with MySql?
Can the data explorer be used with MySql? [message #79881] Thu, 03 March 2005 11:09 Go to next message
Originally posted by: unknown.mydomain.de
how do I have to configure the database explorer to work with MySql?
Zsolt
Re: Can the data explorer be used with MySql? [message #80545 is a reply to message #79881] Sat, 05 March 2005 11:01 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
Zsolt wrote:
>Hi,
>Zsolt
Currently, MySQL is not supported, but look for this post: "Does Server
Explorer support MySQL?" where it is explained how to manually add that
support.
Chemi.
Re: Can the data explorer be used with MySql? [message #85792 is a reply to message #80545] Tue, 22 March 2005 11:56 Go to previous messageGo to next message
Originally posted by: sylcheung.gmail.com
Chemi,
What is the best way to search for that thread?
I try the Web interface of this newsgroup,but it does not have a search
capability.
Thanks for any tip.
Sam
Chemi wrote:
> Zsolt wrote:
>> Zsolt
> support.
> Chemi.
Re: Can the data explorer be used with MySql? [message #86595 is a reply to message #85792] Wed, 23 March 2005 18:54 Go to previous messageGo to next message
Originally posted by: laurentd75___no.sp_am.yahoo.fr
Hi guys,
SInce I was actually searching for the same post myself, and since there's
no search facility in the Web interface, I'm reproducing this post for you
below:
_________________
In order to support MySQL, a data definition needs to be created as
explained in the RDB whitepaper at
http://www.eclipse.org/webtools/wst/components/rdb/Data%20To ols%20Open%20Source%20Overview%20for%20Eclipse%20database%20 Developer.html#_Creating_a_new_database
vendor
Once the database definition is in place, it will appear in the database
managers pane of the connection wizard. You should then be able to
connect using the Other driver option.
_________________
Hope this helps (though the process does look somewhat complicated !!! :)
Laurent
"Samuel Cheung" <sylcheung@gmail.com> a
Re: Can the data explorer be used with MySql? [message #86623 is a reply to message #86595] Wed, 23 March 2005 19:13 Go to previous message
Hmmm... I just forgot to acknowledge the original poster... Oops !!
So.. This excerpt is from a post by Larry Dunnell) dated 25 Feb. 2005, 19.21
hrs.
> Hi guys,
> below:
> _________________
> vendor
> _________________
> Laurent
Previous Topic:WTP1.0M3 -- JSP Syntax Colouring
Next Topic:WTP1.0M3 -- Issue with validation and web.xml editor ?
Current Time: Sat Jul 12 08:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
