Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Problem mapping many-to-many relationship
Problem mapping many-to-many relationship [message #79865] |
Sat, 14 April 2007 13:27  |
Hi!
i have a little question which i had trouble answering; i would really
appreciate if someone could help me straighten it out. here it goes:
in short, im trying to create a two sided many-to-many relationship. i
have two classes, with two collections pointing to each other. i took my
mapping from here (http://www.elver.org/hibernate/ejb3_examples.html).
this is a pseudo ecore model with annotations:
Class A:
|---> property collection AtoB
|---> Annotation:
@ManyToMany(fetch=LAZY cascade=NONE targetEntity="B" indexed="false")
@JoinTable(name="AandB")
Class B:
|---> property collection BtoA
|---> Annotation:
@ManyToMany(fetch=LAZY cascade=ALL targetEntity="A" mappedBy="AtoB"
indexed="false")
from this ecore model, i get the following pseudo mapping file:
<class name="AImpl" entity-name="A" abstract="false" lazy="false"
discriminator-value="A" table="`A`">
<cache usage="read-write"/>
<id name="id" type="java.lang.Integer">
<column not-null="false" unique="false" name="`id`"/>
<generator class="identity"/>
</id>
<bag name="AtoB" lazy="true" table="`AandB`">
<key/>
<many-to-many entity-name="B" unique="false"/>
</bag>
</class>
<class name="BImpl" entity-name="Transmitter" abstract="false"
lazy="false" discriminator-value="B" table="`B`">
</id>
<bag name="BtoA" lazy="true" cascade="all" inverse="true" table="`AandB`">
<key/>
<many-to-many entity-name="A" unique="false"/>
</bag>
</class>
now, i notice that there is a <key/> tag with no column on it. is this
normal? and if not( which i suppose), how can i get it to set the column
key. also, how can i set a column in the many-to-many tag to produce
something like this: http://www.xylax.net/hibernate/manytomany.html
in the database, the join table that is created does not have any FK
columns; which obviously creates a runtime error. all it has is two
columns: "id" and "elt" (i dreally dont know where this elt comes from)
how can i properly setup the many-to-many relationship? could it be
that i must use joinColumn or some other annotation? and if so, how must
i use it?
thanks very much for your help!
best regards,
Re: Problem mapping many-to-many relationship [message #79884 is a reply to message #79865] |
Sat, 14 April 2007 14:53   |
just wanted to say that i managed to find the answer to my question. for
the record, here it is:
i didn't know we could add collections of annotations in annotations. i
actually found it here: http://www.elver.org/hibernate/ejb3_format.html
so, to add a join column to my join table, i added:
@JoinTable(name="AandB" joinColumns={@JoinColumn(name="someiD")})
and gave me a mapping like:
</id>
<key update="true">
<column name="`someID`" not-null="true" unique="false"/>
</key>
</bag>
</class>
and now all works well.
thanks anyways!!
best regards,
Jean-Denis Boudreault wrote:
> Hi!
> Class A:
> |---> Annotation:
> Class B:
> |---> Annotation:
> indexed="false")
> </id>
> <key/>
> </bag>
> </class>
> </id>
> table="`AandB`">
> <key/>
> </bag>
> </class>
> i use it?
> best regards,
Re: Problem mapping many-to-many relationship [message #79899 is a reply to message #79884] |
Sun, 15 April 2007 04:47  |
Hi Jean-Denis,
I am not sure why the fk was not created in your first mapping. If you have time can you post the
stack trace?
Yes a key tag without a column attribute is allowed, hibernate will/should then automatically create
the fk columns (which are id and elt).
The elt field is the fk to the element in the mtm and the id is the fk to the parent.
gr. Martin
> Hello,
> </id>
> <key update="true">
> </key>
> </bag>
> </class>
> thanks anyways!!
> best regards,
>> Hi!
>> my mapping from here
>> (http://www.elver.org/hibernate/ejb3_examples.html). this is a pseudo
>> Class A:
>> |---> Annotation:
>> Class B:
>> |---> Annotation:
>> indexed="false")
>> </id>
>> <key/>
>> </bag>
>> </class>
>> </id>
>> table="`AandB`">
>> <key/>
>> </bag>
>> </class>
>> column key. also, how can i set a column in the many-to-many tag to
>> produce something like this:
>> must i use it?
>> best regards,
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Problem mapping many-to-many relationship [message #604751 is a reply to message #79865] |
</id>
<key update="true">
</key>
</bag>
</class>
thanks anyways!!
best regards,
> Hi!
> Class A:
> |---> Annotation:
> Class B:
> |---> Annotation:
> indexed="false")
> </id>
> <key/>
> </bag>
> </class>
> </id>
> table="`AandB`">
> <key/>
> </bag>
> </class>
> i use it?
> best regards,
Re: Problem mapping many-to-many relationship [message #604754 is a reply to message #79884] |
Hi Jean-Denis,
stack trace?
gr. Martin
> Hello,
> </id>
> <key update="true">
> </key>
> </bag>
> </class>
> thanks anyways!!
> best regards,
>> Hi!
>> Class A:
>> |---> Annotation:
>> Class B:
>> |---> Annotation:
>> indexed="false")
>> </id>
>> <key/>
>> </bag>
>> </class>
>> </id>
>> table="`AandB`">
>> <key/>
>> </bag>
>> </class>
>> must i use it?
>> best regards,
The Netherlands
Current Time: Sun Aug 31 01:21:06 EDT 2025
Powered by FUDForum. Page generated in 0.03632 seconds
