ADJT Plugin Loading / Build Errors [message #7147] |
Wed, 23 October 2002 19:20 |
Originally posted by: john_daly.hp.com
Hello all,
I'm looking to see if others have had problems building relatively large
(800+ classes) AspectJ projects. In short I have created an AspectJ
project containing some 800+ classes and although I was successful in
doing so Eclipse is now producing two errors:
1) Upon opening this project I get:
Problems while opening projects Reason: Problems while opening
projects
Details:
Attempt to load lass "org.eclipse.ajdt.internal.builder.Builder"from
deactivated plugin "org.eclipse.ajdt.ui".
2)Upon building this project I get:
Build problems.
Errors during build.
Details:
The latter problem occured in concert with a lack of memory error for the
Eclipse VM. I'm now firing up Eclipse with the following args: eclipse
-vmargs -Xmx256MB
Any help or insights would be much appreciated.
Thanks.
Re: ADJT Plugin Loading / Build Errors [message #7286 is a reply to message #7147] |
Thu, 24 October 2002 18:32 |
Originally posted by: Mik.Kersten.parc.com
"John Daly" <john_daly@hp.com> wrote in message
news:ap6sp9$7fv$1@rogue.oti.com...
> Hello all,
> projects
> Details:
> Build problems.
> Details:
> -vmargs -Xmx256MB
> Thanks.
John,
My reply to Ron's "Out of Memory" post should address this issue in a way
that's more convenient than re-installing. Let me know if that doesn't work
for you.
Mik
Mik Kersten
Development Tools Lead
AspectJ Team, Palo Alto Research Center
http://www.parc.com/mkersten
Re: ADJT Plugin Loading / Build Errors [message #7301 is a reply to message #7286] |
Thu, 24 October 2002 21:40 |
> > Hello all,
> > projects
> > Details:
> > Build problems.
> > Details:
> > -vmargs -Xmx256MB
> > Thanks.
> John,
> for you.
Mark,
I tried you magic solution but got no magic. I did notice though that I
am now getting the following error inside of Eclipse:
"Plug-in "org.eclipse.ajdt.ui" activation failed while loading class
"org.eclipse.ajdt.internal.builder.Builder".
The Eclipse (.log) file contained the following data:
!MESSAGE "Plug-in "org.eclipse.ajdt.ui" activation failed while loading
class "org.eclipse.ajdt.internal.builder.Build
er".
!STACK 0
org.eclipse.core.internal.boot.DelegatingLoaderException:
org.eclipse.core.runtime.CoreException[2]: java.lang.reflect
InvocationTargetException: java.lang.NullPointerException
at org.eclipse.ajdt.ui.AspectJPlugin.<init>(AspectJPlugin.java:383)
at java.lang.reflect.Constructor.newInstance(Native Method)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:677)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:183)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:58)
org.eclipse.core.internal.plugins.PluginClassLoader.findClas sParentsSelf(PluginClassLoader.java:136)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:750)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:730)
at java.lang.ClassLoader.loadClass(ClassLoader.java:250)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:127)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:164)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:
102)
org.eclipse.core.internal.events.BuildManager.instantiateBui lder(BuildManager.java:486)
org.eclipse.core.internal.events.BuildManager.initializeBuil der(BuildManager.java:441)
org.eclipse.core.internal.events.BuildManager.getBuilder(Bui ldManager.java:327)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:165)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:186)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:146)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:839)
at org.eclipse.core.runtime.Platform.run(Platform.java:416)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:160)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:211)
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:745)
org.eclipse.core.internal.resources.Project.open(Project.jav a:620)
org.eclipse.jdt.ui.actions.OpenProjectAction$1.run(OpenProje ctAction.java:130)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
Re: ADJT Plugin Loading / Build Errors [message #562292 is a reply to message #7286] |
> > Hello all,
> > projects
> > Details:
> > Build problems.
> > Details:
> > -vmargs -Xmx256MB
> > Thanks.
> John,
> for you.
Mark,
er".
!STACK 0
102)
FUDForum. Page generated in 0.03940 seconds
