Home » Eclipse Projects » Equinox » Tomcat servlet interaction with Eclipse
Tomcat servlet interaction with Eclipse [message #79834] Sat, 23 December 2006 11:08 Go to next message
Originally posted by: s0347354.sms.ed.ac.uk
Hi all,
I am trying to write a web application that is able to interact with the
Eclipse environment (i.e. use the workspace, add/remove files to it, get
java compilation errors etc). The problem I am having now is that the
servlets running through Tomcat cannot communicate with the Eclipse
instance to gain this sort of information. After reading a number of
posts on this newsgroup, it seems as though Equinox is the way to
achieve this... however, is there any thing more lightweight that could
serve my purpose, or is this the best way to go about it?
Is there a particular tutorial that anyone recommends for setting up a
simple example that could do such a thing?
Any guidance is much appreciated!
Will
Re: Tomcat servlet interaction with Eclipse [message #79849 is a reply to message #79834] Mon, 25 December 2006 22:39 Go to previous messageGo to next message
Originally posted by: wuxuefeng.kompakar.com.cn
May be you need OHF bridge and Apache Axis.
You could expose plug-ins as Web services, but It need
more test to practice in the industry .
"Will Ryan" <s0347354@sms.ed.ac.uk> ??????:emjkaj$rfk$1@utils.eclipse.org...
> Hi all,
> instance to gain this sort of information. After reading a number of posts
> on this newsgroup, it seems as though Equinox is the way to achieve
> this... however, is there any thing more lightweight that could serve my
> Will
Re: Tomcat servlet interaction with Eclipse [message #79879 is a reply to message #79849] Tue, 26 December 2006 18:20 Go to previous messageGo to next message
Thanks Alan for the suggestion. I'm not sure however that I want to
adopt something that is so early in development, mixed with my
inexperience with Axis, I don't know if this is the best solution for me.
Has anyone else got any more advice/ideas on how to expose Eclipse
plugins to a Tomcat web application???
>> Hi all,
>> Will
Re: Tomcat servlet interaction with Eclipse [message #79896 is a reply to message #79879] Tue, 26 December 2006 23:11 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi Will,
To get started you might take a look here -
http://www.eclipse.org/equinox/server/http_quickstart.php
.... and perhaps more directly relevant to what you're asking -
http://www.eclipse.org/equinox/server/http_in_container.php
This will allow integration at the Servlet API level however it sounds like
you might be after something more generic --nonetheless this is where I'd
suggest starting.
HTH
-Simon
"Will Ryan" <s0347354@sms.ed.ac.uk> wrote in message
news:emsao5$4cm$1@utils.eclipse.org...
> >> Hi all,
the
get
posts
my
> >> Will
Re: Tomcat servlet interaction with Eclipse [message #79956 is a reply to message #79896] Fri, 29 December 2006 07:04 Go to previous message
This lesson maybe usefull.
https://www6.software.ibm.com/developerworks/education/ws-ec lipseplugin/section2.html
"Simon Kaegi" <skaegi@sympatico.ca> д
Previous Topic:Get required plugins
Next Topic:where is 3.3M4? (no text)
Current Time: Tue Jul 22 02:43:39 EDT 2025
Powered by FUDForum. Page generated in 0.04699 seconds
