Home » Archived » Visual Editor (VE) » Question about editing javabeans with VE
Question about editing javabeans with VE [message #79779] Wed, 09 February 2005 12:00 Go to next message
I have a simple javabean, created with VE derived from Composite. Let's
say it has a Text on it, and I've used the "generate getters and
setters" functionality.
Now, I create a new Composite and using the "Choose Java Bean" palette
item, I drop my java bean onto the composite. My bean appears, nice as
can be, and my Text property appears in the property sheet, and I can
expand it to get at its subproperties, like "text". So, I set my Text's
text via the property sheet. Instead of code like this:
beanComposite = new BeanComposite(this, SWT.NONE);
beanComposite.getText().setText("Hi there");
I end up with code like this:
text = new Text(); // error, no such constructor visible
text.setText("Hi there.");
beanComposite.setText(text);
which won't even compile, and even if it did it would cause all sorts of
mischief in less trivial situations.
Am I doing something wrong, or is this a limitation of this early
version of VE? I'd like to be able to put my bean on a composite and
edit the properties of the bean's controls at design time using VE, but
it looks like it does not yet have that capability. Is this correct?
Re: Question about editing javabeans with VE [message #79810 is a reply to message #79779] Wed, 09 February 2005 13:47 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
That's called an implicit property. We don't handle those yet. An
implicit property is where you want to drill down to a property and set
another property on it, where the top property is the default value. We
need to be able to handle this, but that's not available yet. We can
only handle nesting like that when we also created the top level setting.
Rich Kulp
Re: Question about editing javabeans with VE [message #605178 is a reply to message #79779] Wed, 09 February 2005 13:47 Go to previous message
Rich Kulp
Previous Topic:Question about editing javabeans with VE
Next Topic:problems launching the VE
Current Time: Thu Jul 17 23:18:39 EDT 2025
Powered by FUDForum. Page generated in 0.10358 seconds
