OSEE installation - database connection [message #7145] |
Thu, 15 May 2008 11:56 |
Dear OSEE newsgroup,
I am trying to install OSEE on Eclipse 3.3 Linux x86. I downloaded,
compiled and installed all required plugin (I have access to "Define"
and "ATS" perspective).
Could you please provide more information for the configuration, in
particular for the connection to the database?
At the moment, when I try to open the "Define" perspective, I got the
following error: "Unable to get a database connection: Unable to locate
a Connection Factory for the driver type".
The error log signals "Unable to get database connection" with the log I
append at the end of the message (which I suppose is expected).
Thanks for the support.
Kind regards,
Matteo Bordin
java.lang.IllegalStateException: Unable to locate a Connection Factory
for the driver type [org.postgresql.Driver].
org.eclipse.osee.framework.database.DBConnection.getNewConne ction(DBConnection.java:52)
org.eclipse.osee.framework.database.DBConnection.getNewConne ction(DBConnection.java:44)
org.eclipse.osee.framework.database.ConnectionHandler.getNew Connection(ConnectionHandler.java:91)
org.eclipse.osee.framework.database.ConnectionHandler.getCon nection(ConnectionHandler.java:77)
org.eclipse.osee.framework.database.ConnectionHandler.getCon nection(ConnectionHandler.java:66)
org.eclipse.osee.framework.ui.skynet.util.DbConnectionExcept ionComposite.dbConnectionIsOk(DbConnectionExceptionComposite .java:39)
org.eclipse.osee.framework.ui.skynet.search.QuickSearchView. createPartControl(QuickSearchView.java:124)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:370)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:227)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:4080)
org.eclipse.ui.internal.WorkbenchPage$17.runWithException(Wo rkbenchPage.java:3145)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:129)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3296)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2974)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
FUDForum. Page generated in 0.03271 seconds
