Home » Archived » BIRT » How to use/access existing Java Objects as the Data Source for BIRT
How to use/access existing Java Objects as the Data Source for BIRT [message #79771] Fri, 07 October 2005 05:14 Go to next message
Hi all,
I have an Eclipse plugin that has its own data within the client side model.
I want to use BIRT to be able to create reports directly from this client
side model. I would like to be able to expose this model as a data source
for BIRT.
Are there any examples of doing this?
Thanks in advance.
Tim.
Re: How to use/access existing Java Objects as the Data Source for BIRT [message #79801 is a reply to message #79771] Fri, 07 October 2005 09:51 Go to previous messageGo to next message
Tim,
If you are using the engine API to run your report, you can pass in a
prepopulated Java object like:
EngineConfig config = new EngineConfig();
config.addScriptableJavaObject("objectName", objectInstance);
Then in script you can access the object like
var test = objectName.myMethod();
So if your data has some sort of iterator, you could implement this in a
Scripted Datasource and pass your object in with the above code and then in
your fetch method iterate over your results.
Jason Weathersby
BIRT PMC
"Tim Shelley" <tim_j_shelley@hotmail.com> wrote in message
news:di5eah$26h$1@news.eclipse.org...
> Hi all,
> model. I want to use BIRT to be able to create reports directly from this
> client side model. I would like to be able to expose this model as a data
> source for BIRT.
> Thanks in advance.
> Tim.
Re: How to use/access existing Java Objects as the Data Source for BIRT [message #79815 is a reply to message #79801] Fri, 07 October 2005 10:43 Go to previous message
Personnally, I pass a HashMap to the Birt Engine, using
config.addScriptableJavaObject("map", map); in the Servlet calling the
reportEngine.
The Map contains one entry per Dataset i identified for my report, the
key being the dataset name.
Each Dataset entry is Vector of Maps ('fieldName, value') used to fill
the dataset row. I might change this a little, though, since each
field key is duplicated for each row... But it's not my priority yet.
In the report, I use
it = map.get("datasetName").iterator();
in the 'open' method of my dataset,
and I use
if (! it.hasNext()) {
return false;
line = it.next(); // gives me a Map (containing key - value pairs)
keys = line.keySet().iterator();;
while (keys.hasNext()) {
key = keys.next();
row[key] = line.get(key);
return true;
in the 'fetch' method to populate the dataset rows.
OK, this isn't perfect, but it is quite flexible...
I think I'll change the 'open' method to also read the field keys...
On Fri, 7 Oct 2005 09:51:25 -0400, "Jason Weathersby"
<jweathersby@actuate.com> wrote:
>Tim,
>Jason Weathersby
>BIRT PMC
>> Hi all,
>> source for BIRT.
>> Thanks in advance.
>> Regards,
>> Tim.
Previous Topic:Getting the image-name
Next Topic:Is it possible to do data aggregation ?
Current Time: Thu Jul 17 21:51:02 EDT 2025
Powered by FUDForum. Page generated in 0.05168 seconds
